avatar_darthspud2
RAF Super Sha'arm
Started by darthspud2, October 19, 2016, 09:51:54 AM
darthspud2
Just imagine , if you will, that Tornado didn't happen.
What could the British Aircraft Industry do to fill the gap after Wilson's Labour Govt decimated the industry and the RAF needed a complete re-equip.
USAF purchases would have been unacceptable, but buying from a supposedly non-aligned country could be a fair idea.
What we have here is a scaled mock-up of the proposed late life extension for the  Sha'arm , an in country upgrade by IAI of the Lockheed ( later Boeing ) F15
As the Americans wouldn't overtly allow these aircraft to go to European users the IAI versions were the only way the RAF could get front line aircraft.
This aircraft would become the Super Sha'arm although it was more commonly called the Sledge.
Armed to the teeth with guided bombs, Harpoon derivatives, Sidewinder L, Cruise glide bombs and Shrike derivatives along with a capability to carry a full nuclear load should it be required. The aircraft was loved by the crews of the 2nd Banff Attack wing.
The Wing comprised 220 Sqn OCU, 29 Sqn, 80 Sqn & 618 Sqn  based at RAF Martlesham Heath. All the units had previously been Canberra operators or had been stood down post WW2.
I think I'm gonna need a bigger display cabinet!!
Blimey, that's a load-out and a half!  :o :o
 :o Wow...now that's a lot of Boom Bags and Go Get'em sticks... ;D
Pilot better pay attention to which buttons he's pushing!
Nice work!!
Nice one ! She's defo loaded for a fight !
darthspud2
Cheers guys.
I took inspiration from the 2040 Super Eagle advert I found online.
It's really basic F-15C by Monogram and had been sitting in my part built stash for several years.
If my skills were better I'd have done somewhat more with it. from extra rear hardpoints under the engines (like the Tornado GR4) and mer's on each wing hardpoint.
The refuelling probe/housing gave me a headache until I found a Tornado  boom in the spares box , which fitted almost like it was made for it.
It pays to be able to deal with most situations that may arise in life  ;D
I like that  :thumbsup:
darthspud2
I figured that any aircraft I modelled would need to be capable of a multirole mission.
So, Storm Shadow, Sparrow, Shrike, Sidewinder, lgb and a targetting pod should cover most land attack requirements and a secondary maritime strike capability with those Harpoon extended range fitted to the fuel tanks. I think if I do do another I'll square the wing tips and put lau rails on them. And extra hard points under the rear fuselage too.
Martin H
Quote from: NARSES2 on October 20, 2016, 06:40:50 AM
Aint that the truth!  LOL
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
I'm a little concerned about the torsional effects of the Harpoons being mounted on the sides of the drop-tanks like that, plus that the drop-tanks would be "sided".
Maybe if you'd divided the lower half of the tank into thirds & put a Harpoon on the 1/3 & 2/3 marks or into quarters in an X with a Harpoon on each of the lower markers, thereby balancing the load on the pylon & making the drop-tanks interchangeable.
Otherwise: Perfect! You can never be too prepared! :thumbsup:
Nice build! Love the '(over)Loaded-for-Bear' look. :thumbsup:
If you mount wingtip rails, maybe make it a double-stacked unit?
And the phrase 'Boom Bags and Go-Get-Em Sticks' is gold!  ;D :thumbsup:
darthspud2
Good point Old Wombat.
I may get a Hellfire pylon or two and use that rather than the drop tank and put the Harpoon (ER)  on the wing tip,rail and have the refuel option of a boom and no extravtanks.
andyreb3
Loaded for The Russian Bear & Red Chinese Panda .
Just use the outer wing pylon that was planned for it,  like this
my RAF Eagle F.1
Quote from: Rick Lowe on October 21, 2016, 04:50:17 PM
... And the phrase 'Boom Bags and Go-Get-Em Sticks' is gold!  ;D :thumbsup:
;D :thumbsup:
