avatar_RAFF-35
HELP!!!!!
Started by RAFF-35, October 31, 2016, 11:44:55 AM
RAFF-35
Does anyone have any tips or techniques for vacuform models??? Got my first one today  :-\
Librarian
Superglue, several grades of plasticard, many grades of sandpaper, ****loads of patience, test fit as often as possible, don't fear reinforcing the plastic from the inside and outline all parts on the sheet with black marker/sharpie to aid in cutting. Can be frustrating but the sense of achievement at the end is palpable.
Blu-tack when cutting the canopies is also very useful.
RAFF-35
Can't use normal modelling cement then?
Quote from: Librarian on October 31, 2016, 01:18:53 PM
Mmmm.....a really sharp blade usually works for me.   ;)
Yes you can. The vacformed sheet is usually styrene, just like ordinary injection-moulded kits.
Once you've cut the parts from the sheet, sanding them down to the right size is critical. Glue a sheet of sandpaper to a surface you know to be flat. A sheet of glass or a ceramic tile, for example.
Then sand (preferably wet), making sure to apply pressure to the part evenly. Lots of checks during sanding to make sure you're sanding evenly.
Start with a small kit, wash the vacform to get a better key when gluing. Take your time, sometimes the parts don't line up. Don't over sand but keep checking.
Librarian
Apologies...superglue is just my preferred gluing medium. And watch your fingertips when sanding ;D.
RAFF-35
Haha, thanks guys, it's comforting that I'm hearing the same advice from everyone so I know it's solid knowledge  :thumbsup: has anyone got any pictures of their vacforms at all? And are there any benefits to vacform over injection, asides from the oddball factor?  :lol:
dadlamassu
Rareplanes Douglas Divebombers - Royal Iraqi Air Force 1941
Rareplanes Breda Ba-65 - Royal Iraqi Air Force 1941
The Breda's gun turret was really difficult to get to sit properly - lots of sanding, patience, testing and cursing!
Large chunks of my Boeing 777-900 were vacformed.
It used two Minicraft 777-300s, one Doyusha 777-300 and two Welsh Models vacform 777-300s. Melding all the bits together was lots of fun, as you can imagine.  ;D
I used Revell Contacta cement with Slaters MekPak on the joints, and the vacform bits glued very well to the injection bits.
Good advice here!
I don't build with vacuform very often but I found reinforcing the joints with strips of plastic glued from behind to be very helpful. Many times the edges are too thin to glue like an injection kit.
Quote from: RAFF-35 on October 31, 2016, 03:47:33 PM
This is my Airframe 1/72 Martin Baker MB5, used lots of Aeroclub bits & pieces. It was a lot of fun.
RAFF-35
Thanks guys, this has been most useful, I now feel slightly more brace to attempt the kit  ;D
RAFF-35
So this is the suspect in question, a rareplane 1:72 Lockheed U2, however, there were no instructions provided with the kit and whereas I obviously know were the big bits go, there are a few little niggly bits that I'm not sure of.... again, any help would be very useful  ;D
Quote from: PR19_Kit on October 31, 2016, 04:26:08 PM
Dude, that's just nutty! I knew you were into long wings but long fuselage?!   :laugh: :laugh:
