avatar_Dizzyfugu
BAe Hawk 51; HW-309 of the Ilmavoimat's HävLLv 41 (PantherG tribute)
Started by Dizzyfugu, November 19, 2016, 09:08:56 AM
1:72 British Aerospace Hawk 51; aircraft HW-309 of the HävLLv 41 (Hävittäjälentolaivue 41/Fighter Squadron 41), Suomen Ilmavoimat (Finnish Air Force); during camouflage experiments, Kauhava AB, 1995 (Whif/Airfix kit)
by dizzyfugu, on Flickr
Some background:
In 1964 the Royal Air Force specified a requirement (Air Staff Target (AST) 362) for a new fast jet trainer to replace the Folland Gnat. The SEPECAT Jaguar was originally intended for this role, but it was soon realized that it would be too complex an aircraft for fast jet training and only a small number of two-seat versions were purchased. Accordingly, in 1968, Hawker Siddeley Aviation (HSA) began studies for a simpler aircraft, initially as special project (SP) 117. The design team was led by Ralph Hooper.
This project was funded by the company as a private venture, in anticipation of possible RAF interest. The design was conceived of as having tandem seating and a combat capability in addition to training, as it was felt the latter would improve export sales potential. By the end of the year HSA had submitted a proposal to the Ministry of Defense based on the design concept, and in early 1970 the RAF issued Air Staff Target (AST) 397 which formalized the requirement for new trainers of this type. The RAF selected the HS.1182 for their requirement on 1 October 1971 and the principal contract, for 175 aircraft, was signed in March 1972.
Design of the Hawk was conventional by any approach. The two-seat crew - made up of an instructor in the rear cockpit and his student pilot in the front - sat in tandem under a wide field-of-view canopy. Controls at each position were redundant with the instructor having the ability to override student functions as needed. The cockpit was situated well-forward in the design behind a pointed, sloped-down nose assembly. Intakes to aspirate the single engine mounting came in the form of two half-circle openings to either side of the rear cockpit. The turbofan engine was buried deep within the short fuselage which was streamlined with a certain engineering elegance common to British military aircraft.
The intake ducts bulged out at the fuselage sides but were absorbed into the fuselage proper to continue the aircraft's smooth design layout. Wings were fitted amidships and sported modest sweep along the leading edge and lesser sweep along the trailing edge. They were also low-mounted assemblies along the fuselage to help increased expediency for ground operation. The empennage was traditional with a single vertical tail fin flanked by a pair of downward-canted horizontal tail planes. The tail planes were all-moving surfaces to add to the Hawk's agility. Small ventral strakes were noted along the empennage base. The undercarriage was conventional in layout and consisted of two main single-wheeled landing gear legs and a single-wheeled nose leg. The main legs retracted inwards towards centerline while the nose leg retracted forwards.
Standard armament for the Hawk was an optional gun pod commonly fitted to the centerline hard point under the fuselage (there were, in effect, five total hard points). The gun pod housed a 30mm ADEN series cannon for close-in work but remained an optional fixture. There were originally two underwing hard points (later expanded to four) cleared for the carrying of external munitions including guided/homing missiles, rocket pods and conventional drop bombs with the two inner-most hard points plumbed to accept fuel from external drop tanks. Up to 6,800lbs of external stores could be lifted by the Hawk airframe.
The prototype aircraft first flew on 21 August 1974. All development aircraft were built on production jigs; the program remained on time and to budget throughout. The Hawk T1 entered RAF service in late 1976. The first export Hawk 50 flew on 17 May 1976. This variant had been specifically designed for the dual-role of lightweight fighter and advanced trainer. It had a greater weapons capacity than the T.1, featured a total of five hard points, avionics improvements, the ability to carry larger drop tanks of 590 liter (156 US gallon) capacity, and an uprated engine which made the Hawk 50 qualified for 30% greater takeoff weight than the RAF's Hawk T.1.
One of the initial foreign customers was the Finnish Air Force (Suomen Ilmavoimat). In January 1978, Britain and Finland announced a deal to in which the Finnish Air Force was to receive 50 Hawk Mk. 51s in 1980. The Finnish Hawk 51s had a unique avionics fit, used a Saab RS-2 gunsight, and were fitted with a VKT 12.7 millimeter gun pod instead of the 30 millimeter Aden cannon pod provided with the T.1. Interestingly, Finnish Hawks are in some cases fitted with the Russian R-60 (AA-8) AAM, and they are also used for reconnaissance, carrying Vinten optical-infrared camera pods. The first four Hawks in the Finnish order were built in the UK, with the other 46 assembled from kits by Valmet of Finland.
These aircraft were built in Finland under licence by Valtion lentokonetehdas. At that time. the Finnish Air Force was still limited to 60 first-line fighter aircraft by the Paris Peace Treaty of 1947. But by acquiring Hawks, which counted as trainers rather than fighters, capacity could be increased while continuing treaty compliance. These conditions were nullified during the 1990s by the break-up of the Soviet Union, though.
Seven additional Mk. 51As were delivered in 1993–94 to make up for losses, and due to rising levels of metal fatigue, a major structural reinforcement program was carried out to extend the operational life of Finland's Hawks during the 1990s.
More variants of the Hawk followed and common improvements to the base design typically include increased range, more powerful engines, redesigned wing and undercarriage, the addition of radar and forward-looking infrared (FLIR), GPS navigation, and night vision compatibility. Later models were manufactured with a great variety in terms of avionics and system compatibility to suit the individual customer nation. Cockpit functionality was often rearranged and programmed, too, in order to be common to an operator's main fighter fleet to increase the Hawk's training value.
General characteristics:
    Crew: 2: student, instructor
    Length: 12.43 m (40 ft 9 in)
    Wingspan: 9.94 m (32 ft 7 in)
    Height: 3.98 m (13 ft 1 in)
    Wing area: 16.70 m2 (179.64 ft²)
    Empty weight: 4,480 kg (9,880 lb)
    Useful load: 3,000 kg (6,600 lb)
    Max takeoff weight: 9,100 kg (20,000 lb)
Powerplant:
    1× Rolls-Royce Adour Mk. 851 non-afterburning turbofan with 23,1 kN (5.200 lbf) static thrust
Performance:
    Maximum speed: Mach 0.84 (1,028 km/h, 638 mph) at altitude
    Range: 2,520 km (1,360 nmi, 1,565 mi)
    Service ceiling: 13,565 m (44,500 ft)
    Rate of climb: 47 m/s (9,300 ft/min)
    Thrust/weight: 0.65
Armament:
    No internal armament, but an optional VKT 12.7 millimeter gun in a centerline pod;
    Up to 2.200 lb (1.000 kg) of weapons on four underwing hard points, including 4× AAMs like
    AIM-9 Sidewinder or R-60 (AA-8 'Aphid'), bombs of up to 1.000 lb (454 kg) caliber, unguided rocket
    pods, drop tanks or reconnaissance pods with cameras
The kit and its assembly:
A simple build, sparked from a short-notice inspiration when I did online legwork for paint schemes. Then I stumbled upon profiles of fictional Finnish MiG-29 and Su-27, posted in 2011 by fellow member Wenzel from the CZ What if SIG, a.k.a. PantherG here at whatifmodelers.com, featuring interesting, fictional four-tone splinter schemes:
These got me thinking, but instead of building one of the Russian fighters I wondered how this camouflage concept would look on a smaller aircraft already in Ilmavoimat service. This led directly to the Hawk 51!
Thankfully, there are several kits available for this aircraft, and I settled upon the relatively new Airfix kit from 2007. It's main selling point was that it actually contains parts and decals for a Finnish aircraft, esp. a set of the modern, very tiny roundels.
Good experience with recent Airfix offerings were confirmed. Effectively, the Airfix Hawk is a nice and simple build, done in just one and a half day. One of the kit's positive features is the crew: there are actually two modern and well-sculpted pilot figures included, a rarity these days.
The kit was mostly built OOB, only mods are a cover inside of the ventral air brake (which can be built into open position, but this leaves an ugly seam visible) and some extra antennae. Fit is good (not perfect, though), and only little PSR was needed - biggest issue was the ventral wing/fuselage intersection, esp. its rear end.
1:72 British Aerospace Hawk 51; aircraft HW-309 of the HävLLv 41 (Hävittäjälentolaivue 41/Fighter Squadron 41), Suomen Ilmavoimat (Finnish Air Force); during camouflage experiments, Kauhava AB, 1995 (Whif/Airfix kit) - WiP
One truly tricky feat is the mounting of the protective clear separating screen between the cockpit seats – the clear wall has (somehow) to be glued into the clear canopy, without any reference where to actually place it. Altogether a risky business, and I was lucky to get the wall into place with only a little white glue so that a total mess could be avoided. The positive thing about this construction is that you can mount the canopy in open position with the wall inside.
The engraved panel lines appear a little massive at first glance (far from Matchbox' trenches on the Hawk 200, though!), but once you add paint the kit this evens out and looks much better than on the sprues. A nice and literally simple kit!
Painting and markings:
The more challenging part of the build - and I stuck closely to the inspiring profiles and their color choice, choosing a pattern of diagonal "splinter stripes" in rather unique tones:
• FS 35042 (USN Sea Blue; Humbrol 181)
• FS 34227 (Intermediate Green; Humbrol 120)
• FS 30118 (US Field Drab; Humbrol 142)
• FS 35622 (IDF Pale Blue; Humbrol 122), which was also used for the undersides
Painting was done free-handedly, with brushes and some tape for masking, and I stuck to the original color suggestions except for the pure FS35622 on the upper surfaces: I toned it slightly down with a little RLM76 (Humbrol 247), but it is still very bright and the contrast between all colors is really harsh.
Anyway, painting the splinter scheme was easier than it seems, since the areas of each of the four upper side tones was rather small, so that the straight lines were rather short. Only the tight edges needed some corrections, but that was mostly mended during the washing/shading process.
As a design twist, the drop tanks (taken OOB, these are the bigger tanks for the Hawk's export versions) and their respective pylons received the colors of the standard Ilmavoimat Hawks: the pylons were painted in a light olive green (Humbrol 159) while the tanks were painted in a murky, dark brown (a mix of Humbrol 10 and 66) with pale grey (Humbrol 166) undersides.
The cockpit interior was painted in Gull Gray (FS 36231), while other interior surfaces and the landing gear were kept in lighter RAF Aircraft Grey.
For the markings I relied upon the OOB decal sheet; deviating from the inspiring profiles I stuck to the OOB tiny Finnish roundels that were introduced in the Nineties, and they go well with this experimental scheme. Otherwise, markings are rather minimal, just a lot of stencils were applied, the Airfix OOB sheet is pretty exhaustive (with a zillion of stencils, merely 1x1mm in size... There are even decals to be placed on landing gear joints!? Seriously?). As a side benefit, the OOB Finnish aircraft comes with low-viz stencils, placed on a green background. On the fictional splinter livery of my build they blend well into the overall look, the whole aircraft looks very natural (but still original).
In order to emphasize the engraved panel line the kit received a black ink wash and some panel shading through dry-brushing on the upper surfaces, with only slightly lighter tones (e. g. RAL 5008 on the dark blue and RAF Cockpit Green on the FS 34227). I just wanted a subtle effect. Finally, after the decals had been applied, the kit was sealed with matt acrylic varnish (Italeri).
A quick and pleasant build, and it's actually a relaxing experience to build something OOB, without transplants, major, Frankenstein-ish surgery and endless PSR sessions. In fact, the Airfix Bae Hawk kit makes it easy for the builder to create a decent model with little effort. You see that some thought went into the moulds and the kit's construction.
The fictional four-tone splinter scheme looks really weird, though, almost like an anniversary scheme? O.K., it is, according to its creator, actually based/inspired by a pre-WWII Fokker D.VII fighter in Finnish service, but this real life version was created from different and less "loud" colors! Anyway, this Hawk is colorful in a certain way, even though I have doubts concerning its camouflage's effectiveness? However, it's a nice, bright addition to the whif collection. :D
Now that's what I call disruptive camouflage!  :o
Splendid paint job there Thomas.  :thumbsup:
perttime
That is cool!
I don't recall people often doing existing real world aircraft - with a twist.
The real HW-309 some years ago: https://www.flickr.com/photos/j_saari/4915222137/sizes/l
I didn't recognize any backgrounds as "definitely Kauhava" but many are definitely Finland. Looks like HW-309 visited Jämi airfield during the camo trials. Was that for a show, or working with the nearby military installations?
(Jämi on the Finnish airfield data site: http://lentopaikat.fi/en/jamijarvi-efjm/ )
AXU
comrade harps
Man, that is ugly: loud, as you say. Definitely hard to look at and its very hard to look at-ness appearance could be its camouflaging secret  :thumbsup:
Whatever.
Quote from: comrade harps on November 19, 2016, 03:46:05 PM
Migraine inducing camo as a defence measure?  Definitely something to think about.
I like the paint job though.  Good work all round there Dizz.
Thank you very much. Yes, the pics are gathered from a lot of different sites - I take what I can get my hands on, so that at least the countryside matches (even though this does not always work, though...).  There's also a MiG-21MF lurking in one of the pics. No idea what could have been the occasion (maybe an aggressor training?), but it made a nice scene. ;) I'm pragmatic.
Totally agree with the cammo effectiveness - I have doubts, too, even though in one of the flight scenes, over a winter landscape, it shows some effect. IMHO the FS 35522 is much to bright, the contrast to the rest is very harsh. Either a dark green or a medium blue-grey (e.g. RLM 76 of FS 35237) would be more appropriate.
Painting was easier than expected. I have painted a 1:72 Viggen in Fields & Meadows many years ago, and, with a certain masochist twist, a 1:100 VF-1 from Macross, too. Against these, the "splinter bands" were pretty easy and simple.  Probably anything is, though. ;-)
However, the scheme is based on a paper design, and it proves that what looks good in print or on screen does not necessarily "work" in real life. Camouflage is no simple task, and devising a new scheme is more complex than one would expect. This Hawk is a good example, IMHO. Sick, but interessting. It has the appeal of a car accident: looks horrible, but you cannot take your eyes off of it...  :o
What a gorgeous little bird. I'm a big fan of the Hawk, and that's just perfect. Thanks for all the pics as usual !
Fantastic model  :bow:
Quote from: Dizzyfugu on November 20, 2016, 01:03:24 AM
Very much so on both points. I've read a few articles on real world camouflage trials and as you say it is not easy.
Perhaps there is an opening for us "Wiffers" to offer the authorities a "research and test" facility on our models ? Or perhaps they already look ?  :angel:
Personally, I am sometimes very surprised how well some (mostly real world, but sometimes fictional ones, too) paint schemes work once they and their respective vehicles are placed in the intended surroundings. A funny side effect of my model photography - will certainly not replace life tests, but the effects are sometimes surprising!  ;D
Thanks a lot for the feedback, glad you like this "tribute work".  :drink:
perttime
I'm sure FAF did dissimilar training between MiGs and Drakens - why not Hawks too.
There's a couple of aerial shots of Kauhava at http://lentopaikat.fi/en/kauhava-efka/ , if you ever need some again.
I was wondering about the Jämi photos, but it cannot be during a show as the courtyard and airplane parking areas are empty. The Hawk must be heading for the Military training area or artillery range.
Cool.  :thumbsup:  Thank you for the link - might find some good use, since another Finnish whif is in the pipeline (based at Kuopio-Rissala, though).
Snowtrooper
Lovely! :wub:
The part about the 12,7 mm gun pod comes from AirVectors, I presume? AFAIK the 12,7 mm pod was an alternative to the ADEN (and not a substitute) mainly for training purposes, what with 12,7 mm ammo being much cheaper when doing live-fire training and a single 50-cal being equally useless in actual air-to-air and air-to-ground engagements where ADEN would have been used instead. Not to mention that FAF didn't know what else to do with the 500 or so domestic M2 Browning copies left over from WW2. :rolleyes:
http://www.warbirdforum.com/gun.htm
The Mk 66's acquired from Switzerland have definitely been only shown carrying the ADEN in photos, and I've seen several pre-66 age photos of Finnish Hawks with ADEN as well.
Finnish Air Force doesn't even mention the 12,7 mm pod in the technical brief:
http://ilmavoimat.fi/documents/1951206/2016308/Fact+sheet+-+BAE+Hawk+%28english%29.pdf/8dbf74ec-1458-4a15-ad9a-7569839556b5
