avatar_Spey_Phantom
Yakovlev/Embraer Yak-49 "Menace"
Started by Spey_Phantom, December 20, 2016, 12:31:36 AM
placeholder for my GB entry.
about a year ago, i started with the idea to build a Soviet turboprop COIN aircraft, based on the EMB-312 Tucano.
now im gonna revive that project for this GB. basekit will be an Airfix 1/72 Short Tucano, armed with ordanance from an ICM Soviet/Russian Air to ground weapons set.
pylons will be scratchbuilt, with a scratchbuilt Gsh-23 cannon on the centerline (or in the wingroots, im not 100% sure yet).
color scheme im planning is a 2-tone desert camo for operatons in Afghanistan in the mid/late 80's.
Don't forget a shield over the exhaust to try to discourage Stinger missiles
'Menace' is a 'miscellaneous' category NATO reporting name: wouldn't an 'F' name be more appropriate?
https://en.wikipedia.org/wiki/NATO_reporting_name#Aircraft
I finally managed to get the project started, althought i, started with the wings first, to do a fit test for the pylons.
however, i ran into a snagg, i built a Kab-500 and a russian rocket pod to test it under the wings, i found out the pylons supplied by ICM in the weapons boxset is too large to fit under the wings, so i might have sratchbuild some new ones or build this model OOB as a trainer.
i could use the weapons set on the planned 1/72 Mig-39 Flatpack (Mig-1.44)
Quote from: Weaver on January 10, 2017, 07:57:31 PM
acually yes and no. yes, it is an attacker, but its also a trainer, to an M-desigated name would be more fitting (for example the Yak-130 "Mitten")
some pics of the wing progress and the used kit & weapons set:
Sweet!!  Glad to see this under way.
Cool stuff. That's great box art as well. Love the Tucano !
