avatar_Gondor
The P-53 Sparrow Hawk & A63 Taipan
Started by Gondor, January 25, 2017, 09:34:57 AM
Got a bit more done with the P-53 and Started on my A63 Taipan which will be in Australian service. Here are some progress pictures.
The underside had some paint applied to the joints so I can see what additional filler is required
As did the upper surfaces
And here is a side view to show the modified tail, so far
And finally, for now, a picture to show that I have started on the second of my AZ MB.5 kits. This one will be in Australian service, just to confuse people into thinking that it's the CA-15 Kangeroo
There should be more updates over the weekend
EDIT: Put the wrong picture up  :banghead:  :banghead:  Sorted it now so you can see the sprues of the second kit.
A bit more work to show.
This is what you get if you follow the instructions for the walls of the main wheel well bays
And this is what it should look like
The parts are different from one wing to the other. It's possible that I have got the parts transposed but it's not going to be a problem.
Another small update.
Most of the parts are fitted into the Starboard half of the fuselage so it's nearly ready to be closed up. The wings should have the upper and lower parts glued together as well.
The black foam inside the fuselage is an Idea I have taken from @Dizzyfugu  :thumbsup:
I have marked out where I believe the wire supports for the wings will go through the fuselage before fitting into the wings without getting in the way of the undercarriage bays.
Only done a little to the P-53. I did think about putting a late Spitfire Five-Bladed propellor onto it, tried one and thought better of it as the size of the propellor disk is too small for the front of the model, I would have to add to one or the other or even both to make a matching contour. Maybe for another one and another time.
Try a Sea Fury prop and spinner.  Bigger boss so theoretically a better fit, but at the risk of losing one of the MB5s selling points.
"Visit Scarfolk today!"
Quote from: The Wooksta! on September 01, 2024, 08:05:43 AMTry a Sea Fury prop and spinner.  Bigger boss so theoretically a better fit, but at the risk of losing one of the MB5s selling points.
At least it wasn't all torque and no trousers  :rolleyes:
The A63 now has its fuselage together. I hope that I have managed to make a decent job of it. It will be left until tomorrow to make sure that the glue has dried. It took a while for me to get the glue to come out of the container. I had to heat the tube of a new bottle of Contacta to get it clear. I am so glad that I have a gas cooker, makes that job so much easier.
Quote from: Gondor on September 01, 2024, 11:46:40 AMIt took a while for me to get the glue to come out of the container. I had to heat the tube of a new bottle of Contacta to get it clear. I am so glad that I have a gas cooker, makes that job so much easier.
I find the needle applicator has to be cleared prior to use every single session, easy enough to do as long as you have a gas cooker, but a pain nevertheless. I got the Deluxe Materials version at Telford last year and have found the needle doesn't clog, touching all the wood going, so will be getting some more in a few weeks time.
I always have a card of fuse wire handy for such jobs, Usually the middle size does it OK, but sometimes it needs the very small one.
Quote from: NARSES2 on September 02, 2024, 06:03:33 AM
The bottle I had been using was just about empty anyway. You will have to show me Deluxe Materials version in a few weeks time.
A small update on the A63, the clamps have been removed and the joint found to be solid, except behind the cockpit where there is a slight tapered gap. Nothing that a little filler can't fix. So tidying up of the seam tomorrow, followed by drilling the holes in the wings and fuselage for the wire to help hold the wings in place.
I solved the Contacta Pro yrs ago...   .5 piano wire..I always leave it in the tube ..use it..put it back ..easy.
I hated it when I had to heat the tube with a lighter just to use it again ...the wire fixed it prematurely  ;D
I watching this build matey 😀
This bird looks cool 😎
Quote from: Gondor on September 02, 2024, 07:14:02 AMThe bottle I had been using was just about empty anyway. You will have to show me Deluxe Materials version in a few weeks time.
Will do, they've been there the last few years. All the stuff I've had from them has been very good apart from their two part putty (Milliput style) where they tried to be a little to clever I think. I know in a few cases they've almost certainly repackage existing stuff, but they've done it very well and often creatively. They think about how and what you are going to use things for in my opinion.
