avatar_63cpe
Tupovlev Tu-32P "Farmhand"
Started by 63cpe, February 03, 2017, 12:38:37 AM
IMCO by not defining "thin" they can always blame the user for any issues arising.
<cynic mode off>
63cpe
UPDATE:
Fuselage is assembled, exhausts are assembled and painted, cockpit and spine are test fitted. Wings are in puttying fase....take a long time to dry and fill again with next layer. eventually i'll get there. The airfoil of the wing has to be reprofiled as is the leading edge. I didn't use 2c filler for this as I though it didn't need that much filler. Turn out I better used 2c filler.....
IMG_20170211_102336914 by David Dunnebier, on Flickr
Now the projects (Tu-32P "Farmhand", Mig-25 "Foxbat-G" and the Su-15MP "Mantra") are going to be seperated.
David
I do like the way this project is going
This project is awesome! Wish I had thought of it!
63cpe
Update time:
PSR is almost over...now time to polish it. I use black enamel as very tin putty to smooth out small holes and scratches. As this baby will be sprayed in Alu the surface has to be really smooth..Sanding with 800 and later 1000......
BTW: cockpit arrangement is changed slightly, canopy is not fitted yet (still needs some sanding)
IMG_20170303_131137981 by David Dunnebier, on Flickr
IMG_20170303_131151014 by David Dunnebier, on Flickr
David
What a huge beast! Can't wait for some Red Stars und the hull!  :thumbsup:
Im sayin!! This is looking good... shaping right on up!  I can't wait to see this one...
That's a Gnat trainer canopy, isn't it?
63cpe
Thanks gentleman! But it's not a Gnat canopy...its a Tu-22 Blinder canopy. Depainted it last week. In earlier pictures you'll see the difference....
David
Ah right, thanks. It was the slightly curved undersurface that made me think 'Gnat'.
What a big brute ! Love the look of this one.
63cpe
Some progress made: cut out the inner flaps and made new flaps from styrene sheet to make lowered flaps. Trying to get a more "used" look....
IMG_20170317_122052911 by Buddy Holly, on Flickr
Also added some detail in the wheel wells. The main gear is drying when this is written..
IMG_20170317_141231150 by Buddy Holly, on Flickr
David
I'm loving the gear set up.
