avatar_Gondor
My Toolbox just got Bigger!
Started by Gondor, June 21, 2017, 10:41:58 AM
With a dab or two of paint it could BE a figure!  ;D ;)
It's got arms, legs and a face too.....
Quote from: Gondor on January 22, 2020, 01:40:14 PM
Got totaly confused when the Reamer and file set arrived but I could not find the parts which were hideing in the handle  :banghead:
;D ;D
I bought some of that U.V. Light curing glue on E-Bay. I have a specific use for this in mind, but I need to get into the right mood to see if it does the job or not.
I will report back.
Joe C-P
Quote from: zenrat on January 24, 2020, 03:24:40 AM
I got one of these for xmas.
(Image removed, see it above.)
Perfect for painting 1/72 figures.
https://www.hobbytools.com.au/helping-hand-with-magnifier-pcb-holder/
I have one an agree it is great for any of us to hold and see smaller parts.  And you youngsters will find the magnifying glass more valuable over time, as I have been.   :o
I'll admit to buying for around a tenner, a set of the magnifying headworn with light apparatus....and love it....!!  different inserts from x1. 5 upto x3 magnification.....fantastic...👍
I'd still find a way to cut myself using it. :-\
In an order from Wonderland, the neares Model shop to myself,
Flex-Pad Fine
Liquid Polly
Evergreen 252 & 294 which is Square Tube 1/8" (0.125") or 3.2mm and L Angle same size as the square tube.
Always handy stuff
Today the postie dropped off
https://www.amazon.co.uk/gp/product/B07PV9JK5G/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
which I bought to hold my packets of Evergreen rod. I am also using an empty jar to hold my packets of Albion Alloy rod and tubes along with the smaller part used chunkier Evergreen rod items.
I picked up a set of 4 bead reaming files - 2 of which are 5mm diameter or so at the root, tapering to a point and about 2-3 inches long.
Ideal for those small holes you want to be larger...
Got them from Ali, but they're probably available all over the place.
Not my toolbox as such but I popped into my local branch of The Works to get some W&N Matt varnish and discovered they had cutting mats on offer. A2, A3 and A4 in stock so I picked up a nice new A2 one to replace the well used one on my bench for all of £5  :thumbsup:
Literally just arrived via the Amazon  :rolleyes:
A set of ten dill bits in sizes from 0.1mm to 1.0mm
A pair of the smaller Bernier Clamps and only a Tennor, and no I am not looking at insurance  ;D
Was getting fed up trying to cut plastic tubing, and metal tubing and not getting the cut straight so I bought this which arrived today
https://www.amazon.co.uk/gp/product/B08PNTDB3Q/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
No idea what I will do with the PTFE tape  :rolleyes:
