avatar_Dizzyfugu
Modelcollect
Started by Dizzyfugu, July 10, 2017, 01:43:06 AM
LOL! Maybe it's submersible, though...?
Quote from: jcf on February 09, 2023, 01:04:16 PMIntercontinental? The engines would be timed out before they got halfway across the Atlantic.  ;D
That's why it has six engines: take-off on six, cruise on two, keep swapping which two during the flight, then kick in all the ones that will still start for the bombing run... ;)
One I could be tempted with, albeit in captured markings.  Because the vile regime lost.
"Visit Scarfolk today!"
elmayerle
Quote from: The Wooksta! on February 10, 2023, 12:47:24 PMOne I could be tempted with, albeit in captured markings.  Because the vile regime lost.
Diorama of a captured one in RAF markings parked next to a RAF B-35 (HawthroneB.Mk.1).
--Jane Wagner and Lily Tomlin
The RAF B-35s were B(PR)1 'Northamptons'.  ;D
I do have a pair of YB49s that are intended for RAF service.
A nice whiffy addition, even though in 1:48 only (for now): Modelcollect launches an attarctive model of Focke Wulf's tailless proposal for the 1000 x 1000 x 1000 bomber project.
Some built model pics here: http://www.inpayne.com/models/luft46/fw1000.html
I've Unicrap's abortion of a kit somewhere and I located the Planet kit yesterday.
Leading Observer
Quote from: The Wooksta! on February 12, 2023, 05:14:01 AMI do have a pair of YB49s that are intended for RAF service.
Don't forget the RAF B-49 were built by Armstong Whitworths as the AW156 Nodens https://www.whatifmodellers.com/index.php?topic=48454.msg912927#msg912927
LO
Oh I like that  :wub:
And in 48th too  :thumbsup:
Might be easily converted into a 1:72 bomber? Different cockpit interior with side-by-side seating, bogies on the landing gear...? The kit seems to be quite expensive, though.
The planet one was about 25 notes when it came out in 1999.  It's about three times that now.
Three SC1000 on the built up model? That's a terrible shape for an externally carried weapon, the drag would
be horrendous and severely reduce speed and range as the amount of fuel carried would be greatly reduced.
Of course the entire 1000 X 1000 X 1000 concept was daft, all of that expense to carry a single bomb.  :rolleyes:
Looks pretty basic, not a lot of detail and, as Thomas said, a bit pricey for what you get.
Based on the parts breakdown, with the separate nose pod, it looks like it would be fairly
straightforward to do a scale-o-rama into a 1/72nd multi-place bomber.
It's also not that big in 1/48th.
killnoizer
Would you please check this sweet little piece of German engineering ....
https://www.mercedes-fans.de/magazin/classic/phoenix-aus-der-asche-lisbeth-frankenstein-die-wiedergeburt-eines-eilschleppers.16024
It's a Land Rover, NOT a Jeep . Like a Jeep, but for gentlemen.
https://www.spacejunks.com/
