avatar_strobez
Porco Rosso - Savoia S.21 (1/72)
Started by strobez, August 25, 2017, 05:31:19 PM
Glad you're doing this one because I MIGHT (if I find the time) be doing a Porco Rosso 'support aircraft' that would go nicely with it (I have the Savoia kit too and I'm definitely NOT good enough for it yet!).
strobez
That would be awesome.  I actually have a plan to do several Porco Rosso-related builds.  We'll see how many actually get completed, but the grand plan is for not only the Savoia and Curtiss, but also a Macchi M.52 and a Supermarine Stranraer conversion into the Mamaiuto Gang flying boat.  I've also got a neat scratch idea for the twin security planes.
Not sure if all that can get done during just the GB itself, but I'll give it a go.
Thanks!
strobez
The GB officially started, right? So I can get back to work on this one now? I'll give it a couple of days though, in lieu of time already spent on this build.
Thanks!
Quote from: strobez on November 01, 2017, 05:19:28 AM
You could have started quite awhile ago as you're in Seoul, aren't you?
strobez
I am in Seoul, so I'm used to "living in the future"... however I'm always late... so it balances out.
On this build, I'm lucky I have this WIP thread to refer to.  It's been so long since I pulled out this project tray (it was stacked under a few others by now), that I didn't even remember what I needed to do next.  After a review though, I think there's a bit more painting work in the cockpit to accomplish and then we'll be on our way again...
Thanks!
stevehed
I don't know the show but have seen this kit posted several times and it looks a stunner. Just curious but as a mainly  WW1 builder how close to the Macchi M5 is the Savoia fuselage ?
Regards, Steve
strobez
I'm far from an expert, but I've looked at the Macchi M5 as well.  The fuselages are similar, however I think the M5 has a more pointed nose and the cockpit is much closer to the front, so they're quite different.
It took me a while to remember where I left off, but I was able to get a bit more work done finally.  More or less finished off the cockpit.  I took my time and didn't cut any corners - so this is pretty much the best I can do.  One thing I was happy with how it turned out were the pedals.  I didn't like the fact that the 1/72 scale ones were one piece, so I drilled out the space between the pedals and the straps.  A minor thing, but it made me happy... so there. :D
The only things left to do are to a) figure out exactly what colour the chair cushion is supposed to be, and b) give the dash a bit of future so I can apply the dials decal.  Then I can close up the fuselage and get busy on the general construction.
Thanks!
It's a lovely little kit isn't it.
I'd love a couple to whiff.  I can imagine one with a radial engine and one with the wings mounted on the fuselage, jet engine and a twin tail.
strobez
Here's the cockpit all done up.
I've been following the paint callouts from the 1/48 instructions as closely as possible, since I believe they're more accurate.
Now that that's done, i'm trying to figure out what's next.  I dealing with the minor seam now, but soon i'll Have to paint something, and I'm dreading the Tamiya rattle can.  They're lacquer-based paints, right? Can I paint Tamiya acrylics over top? I know there's supposed to be a layer order... but I forgot.  ;D
Thanks!
Quote from: zenrat on November 11, 2017, 01:58:29 AM
A twin tail would be marvelous! :wub: but it is probably too late for our friend to use 2 Q-tip swabs as booms... ;)
I know from experience that Tamiya TS rattle cans over enamel = a nasty crackled mess.
You are prolly OK with acrylics over them but do a test first and don't blame me if it all goes wrong.
strobez
I just read blah blah blah, zenrat said it'd be fine!  ;D
Thanks!
Quote from: strobez on November 13, 2017, 01:42:53 AM
NOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!
:-\ :o :unsure:
Enamels under lacquer is the bugger.  It'll look really good but then after a while the lacquer will crack as the enamel continues to gas out underneath it.
Like this Dodge Charger.  Lasted about a month before this happened.
Charger Cracks 004 by Fred Maillardet, on Flickr
From what I've read & heard enamels can take weeks to months to completely out-gas; lacquers are faster, taking days; while acrylics are even faster, generally being completely dry within a day.
It's generally best to use slower out-gassing paints over faster out-gassing paints - unless you're willing to wait the required full drying/out-gassing time before coating over the previous coat.
DISCLAIMER: All paint drying/out-gassing times are affected by temperature & humidity, & even whether they're matte, semi-gloss or gloss. Lower temperatures, higher humidity & greater gloss increase drying/out-gassing times (sometimes quite considerably). If you can detect even the faintest odour of solvent/paint, it's still out-gassing. Once you can no longer detect any odour give it another hour or two for acrylics, a day for lacquers & a week for enamels. (Note: This is the "very safe" version, which I rarely follow but should - it'd save so many hours of paint repairs! :banghead:)
