avatar_ysi_maniac
Sikorsky S-58 and Westland Wessex
Started by ysi_maniac, September 05, 2017, 01:17:54 AM
BeauWessex: VTOL autogyro intended for special operations
Attack helo with:
-Vestigial wings intended to carry weapons or tanks.
-Jet based in Pegasus that moves rotors too. Nose intake. Maybe 2 or 4 swivelling nozzles.
-Aden cannon ventral pods.
There wouldn't be much room for the crew in there, the fuselage would be stuffed with Pegasus!  :o
Hi, PR19_Kit
IMHO there is room for a Pegasus, but I was wrong adding windows to cabin. Anyway I was thinking that something like a down sized and down rated Pegasus will be enough.
In this image, scale is correct and Pegasus is not down sized
Nicely done.  :thumbsup:
I'm glad I'm not the crew though, the Pegasus turbine is almost exactly in line with those guy's vital parts.  ;D ;D ;D <_< <_<
Land King: land based Sea King (with bits of Wessex)
I like the concept of a 'Land King'. A pity the FAA called theirs 'Commandos' really.
You take two RW models
... and then you get two nice whifs
AS.12
#10
Sud Bi-Bastan S-58, two coupled Bastan VI turboshafts each of 950 shp.  First flew 5 October 1962, the same day as the RAF's first coupled-Gnome Wessex!
Conversion kits were to have been manufactured along with similar packs for the Piasecki 44 / H-21, but ALAT was more interested in the forthcoming Puma.
https://www.flightglobal.com/FlightPDFArchive/1963/1963%20-%202533.PDF
AS.12
Brief but revealing view of the US Navy's twin-T58 HSS-1F from 45 seconds into this video, including details of the access doors:
https://youtu.be/4H0IUH8R5s4?t=45
Quite different to the Wessex installation that used the same basic engine.  The HSS had them mounted horizontally and both exhausted to port.
A very simple Wessex/S-58 whiff, which might slip unnoticed past many a JMN, is to cut a second door into the port side.
Knightflyer
Quote from: ysi_maniac on October 20, 2017, 03:24:37 PM
I know it's probably wrong sizewise, but the top one makes me think of a Westland Wesminster ? (although having just looked at photos the tail-boom is 'plumper' more of a Blackhawk shape?
Oh to be whiffing again :-(
Caveman
secretprojects forum migrant
