avatar_NARSES2
Inspiration
Started by NARSES2, October 02, 2017, 07:07:53 AM
perttime
#120
Some future Schneider racers at http://speedbirdsbook.blogspot.com/
Did anyone yet post:
Lippisch 300-ton WIG.
Snowtrooper
Quote from: Weaver on October 29, 2017, 07:16:11 AM
Random idea: how about a Heinkel He 70 on twin floats, a bit like a precursor to the He 115? The kit's easily available and perhaps a pair of PM spitfire floats might do the job.
You just got ninja'd because a user called "arcticwarrior" just built one (using Blackburn Shark engine and floats) and posted it on BtS:
http://beyondthesprues.com/Forum/index.php?topic=7535.0
I think the elegant He 70 would look better on a single centreline float.
Quote from: joncarrfarrelly on October 29, 2017, 01:57:58 PM
Well I was thinking that the inverted gull wing would be particularly suitable for twin floats on streamlined pylons, but either configuration would work.
Quote from: zenrat on October 03, 2017, 03:18:53 AM
Here's one of my previous boat planes.
I challenge you all to build something this ugly...
Gully Gu-48 Godwit
Gully Gu-48 Godwit 009 by Fred Maillardet, on Flickr
Found this, which put me in mind of that:
That came from this page: http://spontoon.rootoon.com/SPwAi11.html, which also yielded this:
and this:
and this:
And before somebody asks, no, I'm not even slighty into furries: I found the first one on a Google Image search for 'Corsair Seaplane'... :rolleyes:
EDIT: there are loads more pics, some very sketchy but still good for inspiration, here: http://spontoon.rootoon.com/SPwAi41.html
Quote from: Weaver on October 29, 2017, 10:02:26 PM
That's AWESOME!  :thumbsup:
Goodness knows how you'd do it in plastic though.
From the source Weaver posted above also comes this, which Tophe will love...
...and which aligns with some of the thoughts i've been having about asymmetric float planes.
Quote from: zenrat on October 30, 2017, 02:30:29 AM
Yes, I do love this :wub: :wub:
And your own creations in this style may be great also :thumbsup:
There's been a few ideas to convert the Airfix 1/72 HS/BAe Nimrod into a flying boat.
I doubt that anyone has changed the wings from turbojet to turboprop.
Quote from: PR19_Kit on October 29, 2017, 11:59:12 PM
Start with a Caudron C.714, mount the engine upside-down and butt the tail up.  Bugatti Model 100 wings.  Floats from a Curtiss SC-1 /Seahawk.  The Bugatti wings will be the hardest part.
Quote from: Mossie on October 30, 2017, 02:56:37 PM
You forgot the first stage, arrange a World Bank loan to cover the cost of them all.  ;D ;)
Yeah, the fly in the ointment is definitely the Bugatti!
My first thought was DH.88 Comet, if you cut the wings off at an angle (too small?), or possibly use the outer wings from a Mossie and extend the tips (longer wings....).  That might just make the project viable.
If you could live with less extreme taper, Curtiss P-40 wings would probably do the job. You could perhaps fit them with extended wintips to make the taper even more apparent.
The Yak piston-engined fighters all had triangular wings, although with roughly equal sweep on leading and trailing edges: pehaps those could be fitted at an angle by trimming the roots?
