avatar_NARSES2
Inspiration
Started by NARSES2, October 02, 2017, 07:07:53 AM
Quote from: seadude on October 17, 2017, 02:40:26 PM
I have yet to see anybody build a C-130 Hercules amphibian plane.  :unsure: I always hear and read about this from time to time in books and elsewhere, but never see anybody make a model.
http://www.c-130hercules.net/reference-info/articles/a-c-130-hercules-amphibian-makes-too-much-sense-to-be-true-r4/
Lockheed built as large scale radio-controlled model of the project themselves, but I've never seen a plastic model of it either. Time, and a GB, for a resurrection perhaps?
jalles
I was actually thinking about doing this but I couldn't find a good donor for the seaplane portion.  The Hercules is pretty wide and every seaplane donor I found was too narrow.
Quote from: jalles on October 17, 2017, 03:06:08 PM
How about a Sunderland? The old Airfix kit should be pretty cheap these days, and it's not exactly small.
jalles
Quote from: PR19_Kit on October 17, 2017, 03:36:04 PM
Yeah, that was one that I thought of.  I think it's still too narrow, the diagram below should be to scale.
Cut the Sunderland's hull lengthwise and add a "filler" piece of plasticard.  Angle the sides outwards slightly and it should mate with the C-130's hull.   If you need to lengthen the hull, cut it behind the first step and add a section from plasticard (with supports).  Use plenty of filler to make it all match up, PSR, repeat.   :thumbsup:
Also a lot of seaplanes in Porco Rosso including:
Same here, but I don't think I'll be able to dedicate the time.  If I was going to do it, I'd probably carve the hull from balsa.  I've done this for a boat hull and it was surprisingly easy.
Caveman
Bit of a rare one. Float Rota 1 (cierva c30)
This was the only one in reality. But could be one of a number on board a sea-gyro tender?
secretprojects forum migrant
Quote from: Caveman on October 18, 2017, 06:20:03 AM
You couldn't find a big pic then?  ;D ;D ;D
I never knew about that, and I've got a kit of a Rota 1 too, hmmmmmmmmmmmmm.
Caveman
Still finding my way with imgur my previous *not to be named* photo host allowed me to select a size of picture to post.
You can do something like this when linking the image img width=800]https://i.imgur.com/8eTmhqt.jpg[/img (just remember to put the [ at the beginning & the ] at the end, & underlined italics & bold for illustration purposes only).
Quote from: NARSES2 on October 15, 2017, 07:17:59 AM
Quote from: Old Wombat on October 15, 2017, 03:37:42 AM
Seriously, you lot all need to be re-re-educated! :rolleyes:
Don't know about that, but have you seen the size of that torpedo ? Either the crew are midgets or it's .......... :o
In Soviet Union, torpedo drop you...
Quote from: Old Wombat on October 15, 2017, 08:54:00 PM
Quote from: rickshaw on October 15, 2017, 08:11:11 PM
Is Tsar Torpedo!  Is designed to protect the shores of the Rodina from the Capitalist military-industrial complex sea pirates who seek to attack it!    :thumbsup:
Da, tovarishch!
Видеть! Товарищ рикша показал истинное понимание научной социалистической революционной оборонительной военной доктрины! Да здравствует Родина!
(Tranlate for foreign comrades of socialist revolution: Videt'! Tovarishch riksha pokazal istinnoye ponimaniye nauchnoy sotsialisticheskoy revolyutsionnoy oboronitel'noy voyennoy doktriny! Da zdravstvuyet Rodina!)
(Translate for capitalist pig-dogs & vulgar lackies: See! Comrade rickshaw has shown true understanding of scientific socialist revolutionary defensive military doctrine! Long live the Motherland!)
Da, Comrade!  Da!
Мое революционное рвение исходит от учебы в Народном университете. У меня есть степень Риторики! Я получил награды первого класса от Народного комитета по замене сосков для тракторов!
[Кроме того, товарищи, нам нужно наблюдать за этим парнем, он, похоже, является стремительным контрреволюционным реваншистом!]   :thumbsup:
