avatar_Default Setting
Hamilcar Mk. X as a low-cost transport plane?
Started by Default Setting, March 04, 2018, 01:19:27 AM
Default Setting
The General Aircraft Hamilcar was designed as a heavy-duty glider, but as was the case in Germany with the Me 321 Gigant, the option of making it self-powered was explored. The result was the Mark X, which was fitted with two Bristol Mercury engines.
Only a few were made and the concept didn't go further. But what I'm wondering about, is whether the Hamilcar Mk. X might have been suitable as a low-cost transport plane? Or was it too fragile to serve in such a role?
The one duty we owe to history is to rewrite it.
-- Oscar Wilde
Hamilcar was fairly robust, but as an aircraft that was intended to be land conventionally rather than in a controlled crash landing a powered version should be fine I would have thought ?
It's an idea I explored on a smaller scale with a Hotspur.
GAL 50 Porthus 007 by Fred Maillardet, on Flickr
Original thread (with the pics replaced) here http://www.whatifmodellers.com/index.php/topic,41513.msg710884.html#msg710884
There's a large chunk of a real Hamilcar, albeit not a Mk X, at the Army Aviation Museum at Middle Wallop, and it's displayed as if it was being built. There's a guy modelled as if he's sawing up timber for the outer wing and another up on the roof fitting the canopy, all very realistic.
You certainly notice that it doesn't look as strong as a conventional transport, but as Chris says, landing one under control would be different to banging it into the ground knowing that it wasn't ever going anywhere again.
Actually it was developed further as its blood line can be clearly tracked all the way to the Beverley.
I've read that the engines were basically used to 'assist' the take-off when heavily loaded. However, I have a book on radar development that has photos of a Mk.X with a huge radome in the nose instead of the usual doors. Another photo shows the radar dish mounted in the fuselage opening and it fills the whole open area.
Default Setting
Quote from: kitnut617 on March 04, 2018, 07:03:59 AM
Indeed. But apparently it was also able to take off unassisted with a lower load--3.175 metric tons max, which doesn't seem much less than what a DC-3 can carry.
Does anyone know how expensive a Hamilcar Mk. X was to manufacture, in order to have a point of comparison with regular transport aircraft?
-- Oscar Wilde
Can't find anything on the net, but this is an interesting side light on their manufacture.
https://paradata.org.uk/people/joan-gemmell-nee-butler
Martin H
Quote from: PR19_Kit on March 04, 2018, 02:06:06 AM
That would be "TK777". Sorry Kit its a replica. I found that out talking to one of the museum bods when I was there for the IPMS 2016 AGM.
The section at the tank museum is real thou.
It make me wonder if it influenced Bristols when they were designing the Freighter.
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
Quote from: Martin H on March 04, 2018, 02:13:25 PM
A 'Museum bod' told me that most of the fuselage was found after being a lady's garden shed for many years, so they crossed her palm with silver and took it back to Middle Wallop. Then they added the newly built chunk of port wing that's on it now and tidied it up a lot as a display item.
Martin H
Quote from: PR19_Kit on March 04, 2018, 02:25:59 PM
wouldnt you know it, left hand not knowing what the right is doing/saying LOL
Unfortunately,
Quote from: PR19_Kit on March 04, 2018, 02:06:06 AMActually it was developed further as its blood line can be clearly tracked all the way to the Beverley.
No surprise, it's certainly ugly enough to be a Blackburn project!  ;D
Perhaps four engines like the Miles M.40 project, which was to use four Hercules, or four R-2600.
Dimensionally only slightly larger than the Hamilcar, although almost twice as
heavy empty, and at max weight.
Wingspan: 112' (Hamilcar: 110')
Length: 75' (Hamilcar: 68')
Empty weight: 35,000 lb (Hamilcar: 18,400 lb)
Max take-off weight: 70,000 lb (Hamilcar: 36,000 lb)
Max payload: 28,000 lb (Hamilcar: 7,000 lb)
Now I know Horsa's were planned to be re-usable, although I don't know what the actual % was for reused airframe's, I assume they were to be towed/flown out by the way ? No idea if the Hamilcar's were reusable although I would have thought their was a small chance of that happening being factored in when it was designed ?
I guess that would depend on how large the DZ was, or LZ, sorry. Goodness knows how they'd have got a glider tug into the field by Pegasus Bridge, it'd have needed to be a Harrier to get in and out!  :o
There was a scheme to 'snatch' gliders off the ground while the tug flew overhead and there's a good Pathe News vid of it here :-
https://www.britishpathe.com/video/glider-snatching
Quote from: PR19_Kit on March 05, 2018, 09:47:27 AM
That looks fun.
Lot of things to go wrong though.
