avatar_Scotaidh
F7U-3 Cutlass conversion
Started by Scotaidh, April 07, 2018, 08:54:44 AM
Can't you spin em up as you approach the combat zone and keep em spinning but not firing until required?
Quote from: zenrat on October 02, 2018, 04:00:01 AM
I had the same thought, but then thought "if they could, they would have.....surely ?"
Quote from: Scotaidh on October 01, 2018, 01:55:11 PM
As to the targets' point of view ... hmmm.  For some reason, those typically aren't taken into account.   :wacko:
Obviously a "special interest group" waiting to be formed and then apply for funding ?  :angel: ;)
If I recall correctly, the MAXIMUM rate of fire is 6,000 rounds per minute, but I don't think the ones in use today are running that fast. But I may be wrong.
Scotaidh
Quote from: The Rat on October 02, 2018, 12:17:02 PM
Wikipedia insists that there are only two ROFs: either 4000rpm or 6000rpm.  I was under the impression that in air combat, the more bullets one could fling at the target, the better ... hence the eight guns of the RAF fighters in WWII.
In other news, I have discovered that canopies from the P-51, Tempest, and Bearcat will not work on the Cutlass - not tall enough.  Given that the pilot is basically waist-up out of the cockpit, I guess I shouldn't be surprized.  No-one, it seems, makes a replacement canopy for the Cutlass, unless I buy a whole vac-form kit.  Does anyone have any ideas?  If not, I'm going to just going to say a bad word and use the kit's pebbly one, and be grumpy about it.
So there.    :-\ :-\
Scotaidh
Quote from: salt6 on October 06, 2018, 12:10:37 PM
Add some strips to the bottom of the donor canopy?
Mm - might could work, but me, model glue, and clear plastic always seem to combine into a train-wreck of finger-prints, crazing, and really bad language.
Quote from: Scotaidh on October 06, 2018, 01:14:49 PM
Use Clearfix or similar to attach the clear parts to the new frame ? You can then clean any mess up with warm water and a cotton bud.
Scotaidh
Finally it's done.  I'm still working on the back story, and am a bit stuck for a stand, but that's all in the works.  Once that's sorted, it's off to the display case, and on to the next model!  :)
nighthunter
Quote from: nighthunter on October 14, 2018, 08:12:47 PM
She looks a beaut!
Does indeed, all that hard work paid off nicely  :thumbsup: :thumbsup:
Snowtrooper
Looks like a natural development. The blending of the J79's is subtle enough to stay unnoticed, until you see the burner cans :thumbsup:
Steel Penguin
looks ace  :thumbsup:
and it still looks like a space fighter  :thumbsup:
Scotaidh
Thanks, all.  I promise, fewer pics on the next one.  :)
63cpe
Wooow, looks great! Looks slightly more potent than the original. Terrific and love it!
David aka 63cpe
