avatar_jcf
Bizjets, Executive aircraft and related
Started by jcf, April 17, 2018, 08:11:10 PM
Quote from: NARSES2 on April 11, 2021, 06:26:52 AM
I like the fact the passengers are getting out of a Roller  ;D
A Sliver Cloud 1 or II no less. Very 'Of the period'.  :thumbsup:
B-57 Combat Transport for movement of SAC crews.
Yeah, I picked up a B-57 a few years back at Huddersfield to do it but couldn't quite work out how to go about the front end.
Would something like the cockpit area of Airfix's Dominie, recently re-released, be of any use as a starting point ?
I've got an older kit in the stash, the main problem is the bulged roof of the Dominie.  The other problem is the fairly unique shape to the windscreen.
I might revisit it and see what I can think up.
Quote from: Mossie on April 13, 2021, 11:40:07 AM
I had a look at the Dominie again and it might provide the nose.  There are some other models with a longer nose and I've found an image if the forward section of the mock up that's the same.  I still have to work out the glazing though.
https://www.secretprojects.co.uk/threads/martin-vb-57-vip-transport.13348/
The B-57's front end reminds me a lot of an A-6, but implanting THAT would certainly be a challenge. An F3D Skyknight could also be a suitable donor?
I wondered about the Intruder and you're right, trying to match the different shapes  allow for the intakes is probably going to be more difficult than scratch building.  I'll look into the Skyknight, it may be a possibility.
The Dominie with a smash formed canopy might be the best option.
I'm interested in the concept of Bizprops/ Executive Props.  Twin engined light or medium bombers (B-26, Ju-88, Blenheim etc) converted post WW2 to carry a small number of executives in relative luxury.  IRL some A-26s were so converted and so I am sure were other candidates.
Knightflyer
Quote from: Mossie on April 11, 2021, 06:49:05 AM
Am I missing the obvious here? Shouldn't there be a wing spar going through the fuselage connecting the two wings???
Oh to be whiffing again :-(
Naah, enough Gorilla Glue and it'll be fine! ;)
Quote from: Knightflyer on April 14, 2021, 04:37:27 AM
Look at the exterior photos. The cabin occupies the front 1/3 of the wing, so the main spar will be behind the bulkhead on the aft end of the cabin.
Quote from: Hobbes on April 14, 2021, 04:55:56 AM
I'm not sure that it does actually. Checking pics of RAF Canberras the main spar is about level with those twin black stripes around the engines in the main pic, which would take it between the aft-most and centre windows.
Mind you, if Martin could re-engineer Canberras to have GINORMOUS wings like the RB-57D and F, just moving the spar would be a trifling problem.  ;) ;D
