Humbrol Enamels
Started by Doug K, May 05, 2018, 01:49:21 AM
Doug K
Simple question; what on Earth has happened to Humbrol Eamels? I'm quite old school, I still use a hairy stick for my models but even using a pretty good sable, the Matt and satin whites I bought for my Gannet are awful.
It's like spreading a plastic goop, not the paint I know from the (relatively)recent past.
I've only bought one Humbrol Enamel in the last 10 years (metalcote gunmetal) and it is horrible.  Sounds like the same problem - it just doesn't brush out.
I suppose I could've tried thinning it but I just put it to one side and used acrylic.
I've also tried Humbrol clears and liquid mask and i'm not impressed with them either.
I've not bought any Humbrol enamels for years, just their acrylics and with those the pots drive me mad  :banghead: However I find brush painting whites of any make over large areas problematical at best. If I have large area's then I use Halford's Appliance White.
I've found if I mix Humbrol paints in the tin, then seal them properly, the bl@@dy stuff "cures" in the tin. I've even bought a tin that had cured before I opened it!
That was only 2 days after I bought it & it was recently acquired stock according to the store owner.
Don't know who's making their paints now but they're becoming extremely marginal as a useful product.
Quote from: zenrat on May 05, 2018, 02:02:21 AM
The Metalcote colors are an outlier: they use a very different paint formulation compared to the enamels. I've got some Metalcote from a few years ago, and that works well - but only if you thin it.
Hmm, I have been using the Humbrol Metalcote for years and never had problems. With age, the paints tend to become dry and more viscous, but from my experience they take thinning well - and they need to be fluid for a good finish. A bigger brush with more volume than you'd normally use (e. g. with standard enamels) is also recommended, because the bigger paint reservoir in the brush tip keeps the whole stuff fluid for a longer period. Small brushes tend to simply dry out, esp. when you create larger areas.
Quote from: Dizzyfugu on May 05, 2018, 03:14:57 AM
...A bigger brush with more volume than you'd normally use (e. g. with standard enamels) is also recommended, because the bigger paint reservoir in the brush tip keeps the whole stuff fluid for a longer period. Small brushes tend to simply dry out, esp. when you create larger areas.
Good advice but not much use for detail painting car chassis's.
I still have a lot of Humbrol enamels from "before" and they are fine despite being over 30 years old.
Hmmm... :unsure:
I ONLY use Humbrol enamels and I don't have most of these problems, although I have had severe problems with their spray-can varnish in the past (a problem which I believe has now been rectified). I always stir the paint VERY thoroughly. Then I put the paint stirrer on a plastic pallet and ONLY use that as a paint reservoir for the brush: NEVER take paint from the lid or the tin. I occasionally thin it but not often.
I also airbrush it. Again, it seems fine as long as I use ONLY Humbrol thinners (other brands cause problems) and thin it about 2-2.5 parts thinners to 1 part paint. I have a jar-feed single-action airbrush, so it needs quite a lot of air pressure to lift the paint.
It's important to put the lid back on properly. If it's bent, straighten it. If there's dried paint around the sealing surfaces of the tin and/or the lid, clean it off. Press the lid back on as hard and as far as the factory did: I usually put it underneath the bench and then hammer or push on the base of the tin with a lot of force.
Ironically, the only enamel paint I have had consistent problems with is Revell, to the point where I've put all my Revell paints in a separate box and will probably never use them again.
Quote from: Weaver on May 05, 2018, 06:46:48 AM
I can't help feeling there's scope for a tale in the 'Things we did in a miss-spent youth' thread here.................  ;D ;)
Doug K
Quote from: zenrat on May 05, 2018, 04:23:43 AM
I'm the same, I have 30 year old tins that are still fine
Doug K
Yeah, that has been my method too
Doug K
Hmmm... :unsure:
Yeah, I mix thoroughly and only take from the stirrer, the weird thing is that the two whites I'm working with have the same problem, as does the radome tan. If the grey is the same then I'm in trouble.
Me to, including loads of the authentics.
Have you any farther info on this H ? I've almost become paranoid with their spray varnish
Doug K
Quote from: NARSES2 on May 06, 2018, 05:54:39 AM
A good question, I used it on an Irish Aer Chor Hurricane and it ate the decals, very weird.
I just found out from my LMS that they can no longer get Humbrol enamels into the country --- I was told what is on the shelf is all that you can get.
