avatar_NARSES2
RAF Centenary GB - Discussion thread
Started by NARSES2, June 20, 2018, 03:11:58 AM
Here's the initial components for my RAF 100 GB build.
There's two more parts still to come, and yes, there are TWO Rotodynes there, one without a tail................  ;) ;) ;D
For some reason I always find the idea of dropping bombs tail first counter intuitive ?
tigercat
aha the rare Manx Rotodyne. looks like youll have plenty left over for the next GB too ;D
Quote from: NARSES2 on July 02, 2018, 02:44:21 AM
I agree 100%. But the Luftwaffe didn't, viz. the He-111, which did exactly that.  :-\
Quote from: tigercat on July 02, 2018, 05:09:35 AM
Yes, not quite sure what happened to that tail, perhaps I donated it to someone more needy than me? The same kit has TWO rotors in it too, very weird............
Quote from: PR19_Kit on July 02, 2018, 05:20:42 AM
Quite a few tears ago, a B-17 and a CASA 2.111 (Spanish He 111) visited Calgary. I took the tour through both of them (for a grand sum of C$10) and was surprised when I had to crawl over the 111's bomb bay to get to the cockpit from the rear of the fuselage (there's no other way other than climb the under-nose ladder when it's on the ground). The top of the bomb bay was all open and made up of a mass of square holes where the bombs would be hung.  It wasn't very easy to do and I can't imagine doing it if the aircraft is bucking and diving around during a fighter attack.
...and then imagine a freezing cold environment and wearing a thick, so-called "Kanaljacke" - a thick jacket made from sheep skin (incl. wool!) and matching trousers. I have a replica of such a jacket, and it is clumsy, to say the least!
tigercat
just looked on evil bay Airfix Rotodynes are going for silly money  £40-80
Quote from: tigercat on July 02, 2018, 07:14:43 AM
Craziness Rules OK.  :banghead:
It's not THAT good a kit even, the Revell one, albeit in a 'fit the box' scale, is much better detailed.
The Airfix 'dyne is just unique in 1/72 scale.
TallEng
[/quote]
[/quote]
Presumably to build some sort of British kaman HH-43 huskie/kaman k-max synchropter type thing?
Keith
Quote from: TallEng on July 02, 2018, 02:50:03 PM
Hmm, now there's an idea.  :thumbsup:
A double sized Huskie with Rotodyne type rotors would be a very practical device, even if it did take up oodles of shelf space.........
Not a huge stretch either, Kaman would have been the US prime contractor for the Rotodyne.  You might get a Harrier II situation, improvements on the design being sold back to Britain.
Quote from: Mossie on January 31, 2011, 07:49:51 AM
Found a few bits of info on Secret Projects that seem to relate to Kaman studies on the Rotodyne.
The first one is an artists concept, note the fuselage fairings for the undercarriage, ducted fans & roof mounted intakes (similar to the K-140 below), otherwise it's clearly a Rotodyne.
http://www.secretprojects.co.uk/forum/index.php/topic,1084.0.html
Kaman K-140.  Heavier than Rotodyne Z (all up weight for the Z was around 50,000lb), there are some differences in details such as the intakes on the roof (for tip jet gas exchangers?), slightly longer nose, different wing, tail & ramp arrangement.  Difficult to tell but overall dimensions seem slightly larger.
http://www.secretprojects.co.uk/forum/index.php/topic,731.msg5794.html#msg5794
Kaman K-141.  Similar to K-140, but with a conventional shaft driven rotor & long boom with twin tail rotors on a V-Tail.  I suspect it was a comparison to the K-140 using understood technology?
nighthunter
Steel Penguin
that's a slightly worrying thought  :o though I suppose you could load SRAMS   :mellow:
Quote from: Steel Penguin on July 03, 2018, 10:24:11 AM
Specially for the crew!  :o
