avatar_Tophe
MiniSpit-16tb
Started by Tophe, June 20, 2018, 08:22:49 PM
This is a project now, but I have bought the kit and building it may start soon.
I built this Spitfire Mk.16e Heller 1/72 in the 1990s, not finishing it alas (like most models I made in that sad time, looking for too much perfection). Now I am a what-ifer and all changes, I start this model again.
The plastic is no more grey but black, no problem. As I will use putty, this will need paint anyway, sky blue overall I think.
When I bought the Spits 16e in the old time, I was disliking only this Merlin bubble model is in normal injected plastic, not short run, because I preferred so much the Griffon Spit silhouettes (Mk 24 or 22 or 14 bubble).
My first project in 2018 was a STB, Rolls-Royce Spitfire Test Bed, with the canopy just after the propeller and the piston exhausts above the wing. Calling it Mk 16tb (test bed).
Then I thought of shorter wings and fuselage, into a MiniSpit, with much truncation and putty fairing.
Now I think of using the 16tb name for twin-boom, and this may be an asymmetric plane with little fuselage on the port side and micro-boom on starboard, from a middle wing to reach the single tailplane. I will illustrate that with drawings soon.
Here is the genealogy of the project of mine, the 2018 one.
While the Mustang-T paint is drying, I must avoid dust (sanding my Boeing 7474) so this is the right time to start gluing the Spit, in a normal way for a start, so sad... :-X
Now that my Mustang-T model is finished, I can saw, butcher... and the MiniSpit is born!
Putty time is starting:
I do not plan to join smoothly the big front and the narrow rear, there will be a step, but I will try to avoid a hole there, simply. :-\ ;)
After sanding/gluing, while drying:
yes, yes, this has been a Spitfire...
The Minispit is taking shape, yeah... ;D
The extra tailplane will be an extra fin at mid wing on starboard (when the port wing will have a boom towards its tailplane).
For the wings, either I will make like a step in the plastic or glue them a little swept, I will see.
The step in the wing chord has been cut and now the wings are glued on. But I am not satisfied with the result:
My project now is to glue reinforcement under the wing at the chord/fuselage junction, then I will use putty above the wing to have all smooth. I hope.
This is going to work:
The twin-boom asymmetric Spitfire midget is finished:
Just remains paint (black for the canopy).
My son Jacky, 9 years old, painted the underside, thanks.
Normally, I should not show this side, hidden, but this is a step like the others on the workbench.
My Filipino son Jacky painting the side above...
Little boy and little plane... (No, this would be an insult for him, I am sorry) I mean: a big big boy and a tiny plane... ;D
Wonderful to see the concentration  :thumbsup:
Thanks!
Now the twin-boom asymmetric Mini-Spitfire model is finished!
