avatar_TheChronicOne
Vulture B.1 ---- (RAF B-58 Hustler), 1/72 **FINISHED PICS PG 14**
Started by TheChronicOne, July 02, 2018, 02:19:50 AM
I have so many build going I'll likely only be able to manage one. Last GB I barely even finished my single build because of the same reason. So, since, I'll just do one, I'll do a "BIGGER" one and go for a bomber.
I don't know if I'll make any modifications.......  canards perhaps? Just a scheme swap, basically. Light grey underside and green and grey camo upper side. Should be a hoot!!!
As far as I know, I have everything I need. I might have to order in some transfers but I really doubt it. I'll have to go through my stash to find what I need but if I can get by without stealing them from a kit, that would be nifty.
First thing I'll do is get rid of this janky box and find something better to store it in. Not sure when I'll get started, though, but I'd like to get after it pretty quick here... at least start on it, so that I don't get behind.
Good thing is, even knowing nothing about the kit, it should be something that goes together pretty easily, yeah? We shall see!  :thumbsup:
EDIT:  All done!  Check out the pictures on page 14 (maybe 15).
Leading Observer
LO
You could hang a Blue Steel ASM under its belly? Not certain how short-legged the B-58 would become, though...
Needs a "V" name for British service... :wacko:
Vulcan.
Victor.
Valiant.
Vengeance? :unsure:
nighthunter
#5
Viceroy?
Vagabond?
loupgarou
crudebuteffective
vindicator is the name of the bombers in the book of thunderball
tigercat
steelpillow
#11
English Electric/BAC studied a wide range of space launchers in the 1960s, including composite spaceplanes. One of these was a B-58 used as a carrier aircraft, with a conventional (ie wingless) M 20 rocket slung under its belly. The rocket comprised a cylindrical second stage with a tapered fairing on which the orbital re-entry capsule sat, and was about 75% as long and so fat it almost scraped the ground. The drawing number is EAG 4405. Their remit covered a wide range of applications, so an ICBM launcher would not be unreasonable. In fact it would be rather more practical as the rocket need only be sub-orbital.
Would look great in RAF service >cough<
Cheers.
#12
Aye.... I had given a wee bit of thought about the name and I was thinking along the same lines... that it needs a V name. I was also thinking about the rest of the designation. They would likely call it something else like a B.5 or some crap, right?? Not a "B-58" I'm sure.
A nuke would be interesting.... I was contemplating that, also, and doing away with the pod thing. I'd have to find one, though. I'm not going to build one myself. That might take a bit of doing but I'm sure they exist. Hell I have a 1/72 scud missile and patriot missile set so I'm sure there are some nukes out there.  ;D
EDIT: Dizzy mentioned Blue Steel, I'll look into that, as well. Thanks!   All I know is some sort of big missile or rocket or whatever down there would be really cool. I was also sort of wondering how nice it might look sitting there with NOTHING underneath it. I'm so used to seeing this with the pod.
I didn't know there was a 1/72 kit of the TB (extra glass for the trainer) version.  Neat.
Quote from: sandiego89 on July 02, 2018, 05:58:10 PM
Yeah, it's pretty slick! I wanted to build it OOB but the transfers are trashed. At that moment, it became whif fodder and I'm not tore up about it one little bit.  :wacko: :wacko:
