avatar_TheChronicOne
Vulture B.1 ---- (RAF B-58 Hustler), 1/72 **FINISHED PICS PG 14**
Started by TheChronicOne, July 02, 2018, 02:19:50 AM
OK!  So, now I've gotten my camera to talk to my computer again....    Here's the stuff before I got started:
Haven't done anything today but I most likely will here pretty soon.
For some reason I find that colour plastic brings on loads of nostalgia  :thumbsup:
AS.12
Quote from: NARSES2 on July 07, 2018, 02:20:22 AM
Oh yes!  Usually with globs of glue seeping out between joints.  At least until I discovered the Contacta needle-dispenser.
Ah the joys of the origional tube glue  ;D At least when building bi-planes you could do the rigging at the same time as the basic assembly  :angel:
Wow, this month is going by fast...
I'm finally working on this again. I'm trying to get a good number of the tedious things out of the way, and to that end, I started painting the gear and have finished painting the interior pieces aside from the inside of the fuselage halves:
Next I'll give the same treatment to the insides of the fuselage halves then I can glue all this stuff together, or, start working on engines or something.
Eventually I'll have to decide how to address anything that may or may not be hanging from the wings and the pod or.. nuke.. or.. something.
:mellow:
Quote from: TheChronicOne on July 22, 2018, 06:41:24 PM
Sign of getting old mate  ;D  ;)
Some more work has been done on this project. Having a lot of fun with this one so far!  :lol: :lol:
So, all that interior jive from last picture post has been gloss coated. Since it is pre painted and I've no plastic-to-plastic adhesion potential, making the gluing surfaces of this stuff gloss instead of flat acrylic means it actually stays glued.
In addition, I've painted the detail work on the insides of the fuselage halves in the cockpits.
Not much else has been going on, but, I have clipped out and filed/sanded smooth some of the engine parts:
Here's the best part.. I was wondering about how to address the clear parts and I have found a solution that will not only work extremely well, but is copacetic to being lazy as piss.  ;D  I'll explain it better when I actually get to it, but, one hint is that half of the upper paint job will simply be the grey primer I'm already going to spray on it so if I place my camo correctly I can mask in a certain way as to leave the entire front end of this thing masked, rather than each window pane (or some other method.)
Beyond this, looking at the sprues, I'm starting to get down to the wee parts so I better figure out just what they are and make a plan.  :mellow:
Still nothing solid on a name, still leaning toward "Viceroy."
Copacetic?
:banghead:
Please don't use words I have to look up...
;D
Given it's US origin, "Virginia" is probably a better name.
Quote from: The Wooksta! on July 29, 2018, 02:19:17 AM
Which maintains a link to Britain, as the British American colony of Virginia was named in honour of Queen Elizabeth (I), the "Virgin Queen".
Vermont ? If you don't want to reuse Virgina as a name ?
This is why I'm lettin' y'all name the thing. (sorta)   ;D  Virginia is good.
I'm re-visiting "Vanquish" as an option, as well. I've used it once before but I realize that shouldn't disqualify it to be used again. It fits in well with the rest of the Vbomber names.
nighthunter
