avatar_Dizzyfugu
DONE @p.3 +++ 1:72 Cunliffe-Owen Marlin SR.2 of the Royal Navy, Korean War
Started by Dizzyfugu, July 18, 2018, 12:35:57 AM
With some delay, some visual WiP documentation; things started with the cockpit interior and the implanted gun barbette:
1:72 Cunliffe-Owen "Marlin" SR.2 (Whif/converted Fujimi Aichi B7N) - WiP
by dizzyfugu, on Flickr
Worked better than expected - but the B7N2 is not a small aircraft, so there's enough width and internal space for the complete chin turret from an Airfix B-17G wreck.  :lol:
Then the engine - the Centaurus comes from a PM Model Sea Fury. The diameter is fine, but the B7N2's fuselage diameter is slightly oval. I wanted to keep the array of single exhaust stubs (and shunned the potential extra PSR work), so I tried to change the cowling into a more suitable shape. With the help of some subtle force and 2C putty as internal stabilizer, the plan worked like a charm!
The (dry-fitted) five blade prop from the Sea Fury adds some more muscle:
The canopy is also easily adapted to the new weapon station:
The rest remains OOB - just a radar pod was added under the port wing (actually a modified cardboard drop tank from a P-51D):
And as another custom step, the canopy was cut into five pieces, for optional open display:
More to come soon.  :mellow:
Jeepers, that looks BIG, and complicated too.  :o
But putting the model in a VICE? That's a first on here I think.  ;D ;D ;D ;D ;D
Well, the kit is not too complicated - but it is a big aircraft, reminds of an athletic Curtiss SB2C. Very modern lines, though, a pretty bird.
And now image the Spearfish, which was even bigger (20' more wing span IRL and 33% more MTOW)!
Quote from: PR19_Kit on July 24, 2018, 09:27:43 AM
Possibly, certainly fascinated me. Great way of changing the shape  :thumbsup:
Quote from: Dizzyfugu on July 24, 2018, 10:20:38 AM
Yup and my Magna one probably took 200% more putty just on the wing joints  :banghead:
Slowly the pics catch up with the real life status of the Marlin - here's the painting progress:
Further work currently stalls because I realized that I have to order morw white decal material for the ID stripes!  :-\
Doug K
Looking really good, love the subtle use of brute force 😁
loupgarou
I hope the engine won't sprang round again ! :unsure: Maybe the use of heat from an hair dryer (or an hot air gun) while in the vice would have softened the plastic a little so it would adapt to new shape without need for the putty.
The cowling is stable - thanks to the full-width blob of 2C putty inside, which distributes the pressure/tension well. And the cowling actually cracked on one side (hidden under some more putty...), so there's no danger of late collateral damage.  ;D
Good news: the ordered decal material arrived over night, and I immediately started, under 100° F, to add the invasion stripes and other markings. Pics to follow this evening, if either the kit or kit haven't melted away until then...  :banghead:
Knightflyer
As always, another masterpiece in the making (and very nearly done ;D) :wub:
Oh to be whiffing again :-(
Thank you very much!  :cheers:  Yes, the finish line is coming closer, but work is not easy - it's so hot at the moment here that the paint dries up on the brush within seconds! Still some detail work to do, though, I do not think that I will get it finished this weekend. But I might already start with my Sea Fury Mk. XII, the engine and the prop can be prepared separately.
Doesn't it? The B7A has a LOT of whiffing potential. I can see this one in Lufwaffe colors, as well as in an all-dark-blue USN guise, too. Lovely aircraft!  :wub:
