23 Sqdn. DH Venom T5
Started by PR19_Kit, July 19, 2018, 04:08:35 PM
I've now PSR'd the T5 to within an inch of its life, almost every single glue joint on the airframe needed some PSR, and now it's been re-primed and looks a lot better. One more PSR sessions should do it and I can start thinking about colour coats again.
I am looking forward to seeing this one done Kit, as your  recent  FAA and RAF  builds have  been inspiring (see also kick up the a**e) to me
Quote from: PR19_Kit on July 01, 2020, 04:40:08 AM
Just go for yellow T-bands and light aircraft grey with CFS markings.  Be a nice comparison with the Vintage Pair Vampire.
"Visit Scarfolk today!"
KiwiZac
What a great idea, and an epic build!
Zac in NZ
https://linktr.ee/zacyates
As the T5 will ne mostly NMF with broad yellow bands on the wings and booms, as was the RAF's trainer scheme in the late 50s-early 60s, I'm trying the pink basecoat idea for the yellow bits.
I had to mix the pink as I've not got any pink paint with me, Xtracrylic PRU Pink would have done a treat I think, but I mixed their white acrylic with some Humbrol Railway Red in a ratio of about 100:2 to make it.
Yup it needs to be a very pale pink, but still pink rather than an "off" white Kit.
All the proprietary pinks that I know of are way to dark and need a lot of white adding so you are just as well off making your own up to start with.
What's the thinking behind pale pink rather than the previous 'received wisdom' of white?
Asking for a friend.   ;)
Quote from: kitbasher on July 09, 2020, 07:27:32 AM
No idea, but Chris says it works, so I'm giving it a try. I'll report back with pics later.
It'll work, I guarantee it.
I was told by a friend with a science degree that it's all to do with reflectivity or the various reflective indexes of the colours and that white and yellow are notorious for getting a good coating, especially with a brush.
I have absolutely no idea if that's true or not (nor what it means  ;D) and whilst his physics degree was a good one it was a long time ago  ;D But as Lee says, it does work and is especially useful for us brush painters. Saves lots of coats.
Quote from: NARSES2 on July 10, 2020, 06:28:40 AM
From what I know your friend is correct NARSES2
Quote from: Gondor on July 10, 2020, 06:48:34 AM
I assumed he was right, but it was so complicated and then he said "of course that's only the simplified version, in reality it's far more complicated"  ;D
Martin H
Not sure of the why, But its the undercoat colour of choice for JCB......................
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
Oh, its supposed to be PALE pink is it?
Hmmmm.
Damn, me too! I didn't know. When I tried it I used a quite vibrant "Barbie" pink and it did seem to help. Not that I'm denying the method, but I do find it surprising that only a tiny amount of tint to otherwise white paint would result in such a drastic decrease in subsequent coats of yellow.  Pretty cool!  :mellow:
