23 Sqdn. DH Venom T5
Started by PR19_Kit, July 19, 2018, 04:08:35 PM
Good work.
On some other what-if planet, I have found a tandem-seat DH100 project:
Hmmm, I like the look of that................  ;D
Quote from: PR19_Kit on July 22, 2018, 10:27:38 PM
Me to. Certainly has a French look to it  :thumbsup:
Both wings glued on now, and first lot of PSR on the starboard side applied.
Both wings now, but lots of 'S' of the PSR sector to do. Sanding the wing roots is a real pain because the booms get in the way of a sanding block, and files are too coarse so it's strips of wet-and-dry to the fore.
This looks like a possible flying wing/tailless airplane... Booms will provide a different style. :thumbsup:
Knightflyer
Quote from: Tophe on July 25, 2018, 11:20:48 PM
One of the potential Whiffs I've always considered is a Venom with no booms and the tail-fins mounted directly onto the rear of the wings - a sort of 'straight-winged' DH Swallow
Oh to be whiffing again :-(
Or you could give the Swallow the more powerful engine of the Venom...
Did the French have the Vampire T-Birds?
"Visit Scarfolk today!"
Quote from: Knightflyer on July 25, 2018, 11:41:35 PM
Hmm, I'd assume that this solution would be rather instable in the real world - but with some swept wings, for a better longitudal stability...?
Quote from: Dizzyfugu on July 26, 2018, 02:42:29 AM
I'm not so sure, the Fauvel gliders were essentially straight winged and they flew pretty well. But they had to use a reflex wing section for stability and that doesn't make for super efficiency, an essential in the high performance sailplane world.
Maybe I should just leave the booms off the T5? (Sorry Tophe..........)  ;D ;)
Knightflyer
Quote from: PR19_Kit on July 26, 2018, 03:12:43 AM
Cripes, if you partially close your eyes and squint a bit that's practically a boomless DH Vampire!  ;D
Quote from: Knightflyer on July 26, 2018, 05:47:51 AM
Exactly..........  ;) ;D
Which is precisely as far as I've got with the T5 right now, but as it's for the GB I'll probably continue on the original plan.
But I do have another Vampire kit, and maybe a Swallow vacform somewhere too.  ;)
Wonder how well that Airfix Vampire would take a Nene back end from a Mistral?
Knightflyer
Quote from: The Wooksta! on July 26, 2018, 07:10:11 AM
Asking the obvious - how different are they?
loupgarou
Kit, I should say that your builds are very inspirational, but, given the temperature in your and mine parts of the world, I feel more perspirational.  :banghead: ;D
