avatar_ysi_maniac
RAF schemes. Real or imagined
Started by ysi_maniac, July 22, 2018, 12:53:51 AM
RAF Coastal Command
Now that has a "look" about it  :thumbsup: :thumbsup:
A less known, but real, scheme
BTW: Please feel free to add RAF schemes (real or imagined :thumbsup: )
Okay!
Corsair in standard mid war temperate scheme
Same model, whiffed winter scheme:
S2C Goshawk, real scheme-ish.  It was whiffed up as replacement for the one-way trip Hurricanes based on CAM ships.  Probably should have had sky undersides, but I thought white would make for a nice change and was used on larger aircaft like the one Carlos showed:
WW2 RAF temperate scheme with Blue replacing Dark Green.
Northrop N-3 PB 8 by Fred Maillardet, on Flickr
Late 30's/early WW2 with Dark Earth & Dark Green swapped and Black & White swapped.
WW2 RAF desert scheme  with Pale Sand replacing Middle Stone.
Siblings - Kittyhawk & Typhoon 15 by Fred Maillardet, on Flickr
Siblings - Kittyhawk & Typhoon 8 by Fred Maillardet, on Flickr
Magic Fred.  :thumbsup:
That 'reversed scheme' Hurricane looks totally standard at first sight, and it only dawns on that something's not quite right after a while.  ;)
Are colours of bombers, upper surfaces earth and green, the same as early WWII fighters'?
Quote from: ysi_maniac on September 10, 2018, 03:05:03 PM
Yes, but the patterns are different of course.
AeroplaneDriver
nighthunter
