avatar_NARSES2
Whirlwind Mk V
Started by NARSES2, July 28, 2018, 03:11:17 AM
You could add one of the engines you have removed from this one to the nose of another Airfix to give you a Whirlwind trimotor.
A Whirplewind?
Quote from: zenrat on August 03, 2018, 04:32:07 AM
You could add one of the engines you have removed froths one to the nose of another Airfix to give you a Whirlwind trimotor.
A Whirplewind?
Sounds a bit like Vorpalwind.
The vorpal blade went snicker-snack!
He left it dead, and with its head
He went galumphing back.
She's not Italian  :angel:
Anyway to my surprise the nacelles just need a little Mr Surfacer 500 and that will be it, hopefully  :rolleyes: I can then attach the wings and I'll have an airframe  :thumbsup:
Not as surprising as some might think, the length (& weight) of the engines is the biggest difference.
Specifications (Peregrine I)
General characteristics
(Data from Lumsden)
    Length: 73.6 in (1,869 mm)
    Width: 27.1 in (688 mm)
    Height: 41.0 in (1,041 mm)
    Dry weight: 1,140 lb (517 kg)
https://en.wikipedia.org/wiki/Rolls-Royce_Peregrine
Specifications (Merlin 61)
(Data from Jane's)
    Length: 88.7 in (225 cm)
    Width: 30.8 in (78 cm)
    Height: 40 in (102 cm)
    Dry weight: 1,640 lb (744 kg)
https://en.wikipedia.org/wiki/Rolls-Royce_Merlin
Quote from: Old Wombat on August 03, 2018, 06:17:09 AM
A Whirplewind?
Brillig!  :rolleyes:
Quote from: JayBee on August 03, 2018, 12:46:32 PM
A Whirplewind?
Brillig!  :rolleyes:
Someone will have to build a Jabberwock  to use as a target aircraft........ or  possibly a Jubjub bird......... or even a Frumious Bandersnatch.   Come to think of it, didn't Valom once do a Ground Attack Bandersnatch?  Kit may be able to find it in the great book of words.
Had a moment of truth yesterday. This is the first piece of major plastic surgery I've done since I was a teenager I think and it's been a steep but, on the whole, an enjoyable learning curve.
However after I'd assembled the wings yesterday and was admiring how well they fit, credit Airfix back in the day, I noticed that the port engine nacelle was out of kilter. It was angled upwards at probably somewhere between 5 and 10 degrees  :banghead: Looked even worse with the prop test fit to it. The starboard one was fine and whilst the problem wasn't obvious from head on, from an angled side view it was  :banghead:
First instinct was to fret about it and then ignore it. Get it finished, put it down to a lesson learned and then park it in a box after completion rather than take it to Telford.
Half hour and a mug of tea latter I thought "NO", bit the bullet, got the razor saw out and cut the offending nacelle off. It will go back on with a plastic card shim to bring it into line.
This problem was basically caused by my inability to cut a decent 90 degree line  :banghead:
So project delayed, but still ongoing and I'm actually quite proud of myself for doing the "right" thing. You lot are corrupting me  ;)
You are not alone.
With the wonky cutting that is.
I was corrupted years before I found this place.
Looking forwards to seeing more progress pics in due course, Chris.  This has really caught my imagination.  Love the Whirlwind and had a really pleasant experience building the Airfix kit.
Quote from: kitbasher on August 05, 2018, 03:44:03 AM
Yup the Airfix kit has been a very pleasant surprise and I have a couple of other ideas. Perhaps a navalised one, but with radials (I've asked the question on the dedicated Whirlwind thread http://www.whatifmodellers.com/index.php/topic,6954.msg817458.html#new) and even a two-seater nightfighter ?
I must crack open one of my Special Hobby ones to see how it builds.
The reset nacelle has had its first psr session and after some priming it's not as bad as I thought  :thumbsup: Might just need 1 or possibly 2 more psr sessions before paint  :thumbsup:
Have found I have the remains of an old Frog Hornet. So I'm seeing a late production Merlin engine'd Whirlwind used in the low level pr role looking all pretty in pink.
Quote from: NARSES2 on August 08, 2018, 06:42:22 AM
Why do I tempt fate so ?  :banghead:
The p.s.r. was looking good and then I noticed something. The nacelle that I'd reattached was looking slightly longer then the other one. I put it on a nice clean cutting mat and sure enough it was  :-\ Only by 2mm or so, but I now know it's to long and as I seem to be breaking, or at least attempting to break, all of my bad habits on this build I decided I needed to fix it. So I've dug up an old spinner back plate from "the box" and it's the correct diameter, obviously ex Spitfire, and just about the right thickness. So it's been attached to the other, shorter one and filler applied. One step forward and ...............
Anyway it is the RAF 100 GB so Per ardua ad astra as some would say  ;)
I fear I'm letting this build get to me a bit so as there's time a plenty (famous last words) I'm going to park it for a day or so and work on something more straightforward. Then clear the bench and my mind so I can tackle this cowling and get it sorted.
P.S.R. ; P.S.R. ; P.S.R.  :rolleyes:
