avatar_Hobbes
Vickers VC-10 Superb
Started by Hobbes, August 05, 2018, 08:38:49 AM
Quote from: McColm on February 04, 2019, 07:43:01 AM
1/72 scale might be a bit tricky.
there are 2 1/72 VC-10 kits (Magna and Anigrand, IIRC), but you need 2 kits to make 1 Superb so that project would involve a bit of sticker shock.
I can scale the engines to 1/72 fairly easily.
Quote from: Hobbes on February 05, 2019, 01:01:52 PM
Three is you count the Airways Vac Form kit, got one in the stash too ---
Quote from: Hobbes on February 02, 2019, 07:47:54 AMI've more or less finished this (and I got it done in time for Telford). There are a few items I still need to sort out (the decals need repairs).
Another set of RB.178 engines (same basic design I used for the Jet Belfast, now in side-by-side configuration):
Next to a standard VC-10 (the RB.211 test bed G-AXLR, based on the Airfix kit), you can see it's much longer. If you look back at the photos at the start of this thread, I hacked up the Roden kit (which is a Super VC-10) and inserted 2 fuselage sections, totaling 17 windows.
Can anyone see the images in this post? I can't, which is weird, because the image URLs are all valid.
Quote from: Hobbes on September 29, 2022, 07:09:07 AM
All blank
No I can't see anything either Harro. All the pics in this thread have disappeared.  But I think I know what it might be as I had a similar problem a while ago. For me it was the photo hosting website not having its security certificate renewed. I was able to get them to appear when I changed the settings here in my profile to accept the hosting site as unsecure.  But that was before our big forum update, I think I'd better go check my posts to see if any of mine has disappeared again.
EDIT; It seems like the settings I change in 'My Profile' carried over to the updated forum.
That's odd. I switched my hosting to secure a while ago, today I updated the links in this topic to https thinking the images would be visible again, but no luck. Stranger still: my avatar uses the same hosting site and it is visible.
I think I've found it: the image URL uses uppercase letters.
The new forum software converts this to lowercase.
which means the url is incorrect and the image is not found.
Changing case didn't help. The original filename contains spaces, which are stripped by the forum sw.
FXII
I tried to type the image url in lower case, but unfortunately still no pictures. Is there any other way for you to show us this great project?
This is annoying cause I've always loved the lines of the VC-10 and I'm very interested to see what this looks like .
Does this work? Looks ok in Preview
EDIT: Looks as if it does. What I did was this.... opened a link that Hobbes had in one of his posts in a new tab, then Replyed to a post and used the "Insert Image" pictogram. I then copied the https info from the tab which had the picture and put that where the https was in the window that opened when I clicked on the "Insert Image" pictogram.
FXII
Ta Da, there they, perfect pictures!
Thanks
YES!!  We have a picture  ;D
I like what I'm seeing and now we need more ..bloody nice work Gondor mate..bloody nice work for sure  :thumbsup:
