avatar_NARSES2
The Racing and Competition G.B. General Discussion
Started by NARSES2, September 23, 2018, 05:54:35 AM
loupgarou
Quote from: zenrat on October 29, 2018, 02:56:08 AM
Those requiring scrutineering form a civilised queue and have your wallets ready.
I am preparing the wherewithal for the GB. Still have some Soles de oro from Peru, or maybe french Indochina piastres would be more appreciated?  ;D
TallEng
Quote from: Nils on October 29, 2018, 01:08:49 PM
-1/72 Spitfire Mk.XVI racer (thinking if calling it the "Red Devil" or the "Green Fairy (or Goblin)",depending on the color)
-1/72 F4U Corsair racer (same as above, stinnneed a name)
-1/144 Air racing diorama (im thinking a air racing pylon, with 3 smaller aircraft taking a sharp turn arround it, might be a bit complicated to make).
Well the spitfire could be sponsored by Fairy Liquid, a well known (in the UK at least) green colored washing up liquid, I believe the bottle was colored green and white at one stage?
See here https://www.google.co.uk/search?q=fairy+liquid&client=safari&hl=en-gb&prmd=isvn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwirjKHozKzeAhVFiqQKHdjcA08Q_AUIEigB&biw=1024&bih=649
And how about The Black pearl for the Corsairs name? Might look pretty sharp in gloss black pearlescent paint?
Keith
Quote from: loupgarou on October 29, 2018, 02:21:07 PM
I have some DDR Reichsmarks stashed away somewhere, smuggled out in the 70s.
Probably worth at least 2p by now though.  ;D
Quote from: TallEng on October 29, 2018, 02:33:48 PM
Wouldn't that be more appropriate for a Firefly?  :wacko:
Quote from: PR19_Kit on October 29, 2018, 02:54:42 PM
I think Confederate bank notes have finally valued up to that
TallEng
Quote from: Weaver on October 29, 2018, 05:29:45 PM
Indeed ;D my thoughts exactly two seconds after I pressed Post....
Keith
Quote from: TallEng on October 30, 2018, 12:08:31 AM
Keith
The upside of a Firefly would be that you could easily give joyrides to help pay for the racing.
I'm not sure to what extent a Firefly's performance could be made competitive. The Mk.1's top speed of 316mph with a 1700hp Griffon wouldn't cut it, but Mk.4s onwards had 2300hp Griffons, which I can't find a speed figure for. There's also the issue of lightening and cleaning the airframe up, and how much difference they'd make.
TallEng
Quote from: Weaver on October 30, 2018, 06:16:43 AM
Keith
I've seen 386mph at 14,00ft quoted on the web, so if you cleaned it up a bit (around 6,200kgs in fighting trim)* and lost some weight... 400ish mph ought to be doable, trouble is if your mate turns up with a Spiteful say (4,200kgs in fighting trim and 494mph flat out)* with the same engine and some  cleaning up/weight loss.....
*all figures in "ish"
Keith
Doug K
I just can't stop thinking about the 1947 Schneider Trophy........
Spitfire 22/ Seafire 45
Sea Fury
Bearcat
Privateer FW 190
Macchi 202
Not sure I can afford all the Spitfire floats I'd need at £15 a pop for Bren Gun's Vs or IXs!
TallEng
How about using Revells Re-pop of Matchbox's Twotter? It comes with alternate land/float U/C and seems to be available for around €10. The floats might be a bit big, (probably easier to make smaller than to make a small float bigger?) but then if your putting a late mark on floats it would probably need bigger floats.
Spitfire Vb approx 3,000kgs
Spiteful XIV 4,200kgs (that's a very late mark Spitfire I know :rolleyes:)
Keith
loupgarou
Quote from: Doug K on October 30, 2018, 12:54:30 PM
Sea Fury
Bearcat
Privateer FW 190
Macchi 202
You'd better upgrade to a Macchi 205, or Fiat G.55, for the italian entry.  ;) Or even the G.59.
PM Models did a float Spit. You should be able to find it cheaper.
Cunning Plan #1 was supposed to be a re-engine/re-wing job but it's looking more like a re-fuselage job!  Nevertheless should be straightforward.
Given my habit of biting off far more than I can chew GB-wise I'm fighting off the temptation to have two builds going.  I know exactly what Cunning Plan #2 would be - I have the components - so perhaps I'll remove one of the components from the SMW KitSwap stash reduction pile and hold it in reserve should a second build appear feasible.
Sea Fury
Bearcat
Privateer FW 190
Macchi 202
Sabre
Ouragan
Venom
MiG 15
Same float issue mind.
Quote from: TallEng on October 30, 2018, 10:59:53 AM
Keith
Keith
Youi could always persuade a pretty girl to go and put a lipstick kiss on the Spiteful's wing: that should cost it 20mph at least... :wacko:
Quote from: zenrat on October 31, 2018, 01:52:14 AM
Sea Fury
Bearcat
Privateer FW 190
Macchi 202
Sabre
Ouragan
Venom
MiG 15
1957 - Gnat. Folland/Hawker sponsor a one-make class to promote sales, with subsidised/loaned aircraft for 'promising' teams...
