avatar_Dizzyfugu
DONE @p.5 +++ 1:72 Cornell/Jackson "American Spirit" Reno Racer
Started by Dizzyfugu, January 04, 2019, 01:20:41 AM
That's AMAZING Thomas! Can't wait to see the finished article.  :thumbsup:
Thank you, but it will take some more time. But I am amazed how close I come the the real thing - or at least to what I know about it.
Currently integrating the F-100 front landing gear well, taken from a Tamiya/Italeri F-100D. The good thing: the kit comes with a separate well, so the implantation is rather easy since I have complete side walls, covers and the whole strut with the twin wheels. I also started work on what I think are exhaust stubs on the upper fuselage, at the wings leading edge.
1:72 Cornell/Jackson Special "American Spirit" Reno Racer - WiP
by dizzyfugu, on Flickr
For both details I first finished the fuselage and then started cutting away material again. Not the most elegang method, but with so much putty and plastic involved in multipe layers, I think it's the most efficient strategy. And it seems to work - the front wheel well slipped into position like a charm, and it even appears plausible! The exhaust ports are more tricky, but thing unfold better than expected.  :lol:
Yesterday the basic work has been completed: wings were mounted, as well as the stabilizers to the tail. The latter are supposed to come from an F-86H, "de-swepts". Since I could not find any good indication what this would have meant in real life, I went for my own solution. I found a pair of F-86A stabilizers, but found these to be too small, lacking depth. Then I tried a single F-86D stabilizer as an alternative (which has a bigger span), but it still looked goofy and much too fragile Then I tried a pair of MiG-15 stabilizers, and their shape and sweep looked much more conclusive on the T-2 tail, even though a little too small. Eventually I used the wings from an 1:144 Tornado (Dragon), used the MiG-15 parts as sweep benchmark and the F-86D for the span, tailored the tips, and had a pair of suitable stabilizers for the American Spirit!
I also mounted the landing gear - and it looks as weid as expected. The T-2 track is really wide (18.5' in real life), and the struts are very long, too. The F-100 front leg was cut down, but I kept a slight nose-up stance in order to protect the propeller. And the wheelbase is just a mere 6'!!! But this matches the description of the real design, so I must have come close to Cornell's original idea, placing the front wheel well behind the engine, under the wing roots.
This morning I also completed the propeller, added three P-3 blades to the C-130 spinner. This looks menacing!  :wacko:
BTW: the whole thing strongly reminds me of the ill-fated (but much bigger) Curtiss F15C (which also carried a jet engine under its tail boom):
I am still not 100% certain concerning the paint scheme, and it becomes time to settle on that. I will probably add an overall coat of white primer first, creating a good basis for further work and also in order to check the surface of this putty build. I somewhat favor something like this, Bicentennial-ish:
nighthunter
If I may, Thomas, how about a mix of the Bicentennial and USAF Thunderbirds schemes?
The Thunderbirds were also an idea - I have a decal det for an F-16 somewhere. But I favor a blue nose with stars all over, I am just not certain about the rest... I even consider an asymmetrical design. Not an easy decision.
Still some detail work to do, though, and I am afraid that the white primer will have to wait until next weekend due to poor weather and light conditions outside at the moment here.
BTW, updated the previous post with WiP pics, and here's what the beast looks like now:
De-swept is pretty easy, you'd either take out a wedge from
the leading to trailing edge, wider at the front, or add a wedge
from the leading to trailing edge, wider at the rear. Either way
would make center of chord of the surface perpendicular to
aircraft centreline instead of at an angle.
If you have or can find, the Hasegawa 1/72 F-104S NATO 50th Anniversary boxing, it has a mass of stars and such for the decals.
nighthunter
Quote from: kitnut617 on January 14, 2019, 01:07:40 PM
Sadly, I just googled it, and it isn't available anywhere. Yet.
I have a sheet with a zillion of WWII US Army stars from TL Modellbau. A good opportunity to use them!  ;)
Progress slows down. Did some detail work around the exhaust ports and the cockpit, and found some (more) minor dents on the hull.
Quote from: nighthunter on January 14, 2019, 01:25:03 PM
I think it was released a long time ago NH, the boxing of it in my stash has been there a long time. I was just looking at it on Sunday while I was "counting' the stash.
jalles
Wow, that's looking excellent! That side view really shows off the short wheelbase, the prop ground clearance sure looks tight.
Quote from: jalles on January 16, 2019, 10:39:12 AM
Agreed   :thumbsup: :thumbsup: :thumbsup:
The short wheelbase reminds me of a Ryan Fireball
loupgarou
What a beast!  :thumbsup: The first photo makes me think of something russian.
