avatar_JayBee
Vac-form canopies going yellow
Started by JayBee, January 07, 2019, 11:42:35 AM
As the title says, I have some vac-form canopies that have started to go yellow.
Does anybody out there know of a way to reverse this.
They are from the Special Hobby F2G Corsair in 1/72.
Could it be the material that has been used to create them?
I have several sheets of Falcon canopies that are far older which are clear as anything!
I would be most grateful for any helpful suggestions.
Jim
Lord_Voyager
It's the UV in the air from non-incandescent light bulbs... I have the same issue with vacuformed ABS and plastic. There are commercial brand cleaners but I find that the methods here:
http://www.howtocleanstuff.net/how-to-whiten-yellowed-plastic/
this should help you out.
"Visit Scarfolk today!"
Once the chemical reaction starts, that's it.  All you can do is get a replacement.
It's not a UV issue.  I've several MPM/Special Hobby kits where the contents haven't been out of the packet, just stored in a box well out of sunlight and the canopies are now a nice deep gold.  I mean, you could get away with it for the TSR2 (gold in the canopy glass) but not a Ju 388K.
Strange enough I was looking at a CMR kit this morning and the canopies had started to turn, whilst a couple of far older ones were as clear as the day they were formed. I've never found rhyme or reason for the process ?  :-\ and yes I've not found a way to fix it.
I've seen it on old toy packaging which I presume uses the same material, albeit thinner, for the "window".
I've seen it happen with Lego too.  Late 70s onwards.  White, yellow and blue are always the worst affected.
Quote from: NARSES2 on January 08, 2019, 06:10:19 AM
Different types of plastic used for the particular canopies, nothing to do with the age of the kit.
Logical Jon  :thumbsup:
Rather naively I just assumed that they'd have used the same type of plastic, but then to me plastic is plastic. Now try getting me on the subject of different types of "steel"  :thumbsup: ;D
Quote from: NARSES2 on January 13, 2019, 04:20:37 AM
It's all metal 'innit?  ;D
Quote from: PR19_Kit on January 13, 2019, 08:36:21 AM
Depends on the PSI you want to put through it I would guess
Quote from: Gondor on January 17, 2019, 01:39:04 PM
Is that irony?
:o
Going through my stash over the weekend and found I have a M&E Models Jetranger conversion (can't remember when I got it) which is vacuformed in clear. And it's going yellow now too. But the RarePlanes clear vacuform one I also have is clear as clear (they're packed together in the same box)
