avatar_63cpe
Curtiss C-46 Jet Commando pictures: page 2
Started by 63cpe, February 02, 2019, 12:07:47 PM
63cpe
Now doesn't this look classic and kind off "right". All flying surfaces are just glued on. And soon PSR is starting. Will finish this in classic Braniff colors and markings.
IMG_20190202_202109529 by Buddy Holly, on Flickr
IMG_20190202_202129824 by Buddy Holly, on Flickr
Think I'll keep it as it originally was: a taildragger.
David aka 63cpe
AS.12
That's a real brain-melter!  Looks like a fat Comet before the brain says 'hang on a mo...'
loupgarou
Wicked!
Scale and components, please? Did you use the Williams kit? I hope not the ancient vacuform from Sutcliffe/Contrails!
And the Comet?
63cpe
Thanks! the fuselage is the Williams bros...assembled ages ago but had some melt spots (aggressive glue?).  Comet wings are from an 1/100-ish 4c kit by VEB plasticart. This kit was part of an estate I bought some years ago. It was partly assembled and not fit for resale, so decided to keep it.
David aka 63cpe
AeroplaneDriver
That looks like it's going to be a a winner!  As you say, it looks so....RIGHT!
I'd round off the windows though.
I like the idea of the classic Braniff colours, would that be the red and blue stripes of various widths along the fuselage?
Nice one ! Looks right at home in those wings. Buffalo Joe !
Ed S
Those wings go good on the C-46 fuselage.
Air21
That is gorgeous...  :wub:
I always thought those wings belonged on a DeHavilland Albatross, but those kits are about as common as... Well as a DeHavilland Albatross  :banghead:
Looks good Dave.
What's the fit like on the Commando kit?
63cpe
Thanks gentlemen!
@Zenrat: fit is so-so. The chord on the c-46 is quite big. Bigger than the chord of the Comet's wings. I mated the top of the Comet's wings to the top of the C-46 wing roots. Because of this gap in chord I had to move the wings more forward about 1cm. This was no problem anyway as it's going to be an taildragger anyway...
More to the rear were the trailing edge meets the fuselage meets, the gap changes from 0 to about 6mm over a length of about 5cm.
Another thing is the thick trailing edges of the wings. They are about 5 mm at the flaps and ailerons! I'm thinning them down with Dremel and sanding disk.
The rear planes come from an Academy B-17 D (I think). Fit is also poor..lots of putty needed! I've V-ed them a little for good measure..
David aka 63cpe
Thanks Dave.  I was asking because i've always liked the look of the Commando and would like to build one.  I prolly should have been clearer.
But it does look "right" I must admit.
63cpe
Ah, the fit of the c-46? Yeah, that's in par with Airfix, Revell of the same age. So, filler will be needed. But beware with too agressive toluene stuff as parts are moulded thinner than the Revell, Airfix stuff..
David aka 63cpe
Uh, that's sexy!  :wub:
Great idea - and it looks very good so far.  :thumbsup:
