avatar_Tophe
Twin-Whirlwind & Catalina…
Sorry, I'm just now catching up:  A single tail P-38?????
...wheels are turning, my mind is churning....
QuoteSorry, I'm just now catching up:  A single tail P-38?????
yes :D
Using a mosquito tail :lol:
My Bf-109Z is nearly done. Only need to sand the tail now.
At http://www.secretprojects.co.uk/forum/inde...hp?topic=791.15 was presented a Campini project of 1940 with twin motoreattori, "wingspan 18,8 m, max speed 1050 km/h? the motoreattori were to be driven by 1350 HP engines". :)
Obviously, this simple bimotore (below left) had to be turned bifusoliera trimotore (below right)... :wacko:
And here comes a modified version
Need extra capacity? Solution = Twin A-380!
a different Twin A-380 (A-388, photographed!) is at
http://www.cardatabase.net/modifiedairline...php?id=00007492
Thanks for your nice additions, B777LR... :)
I like it. Can you post a profile view.  :wub:  :wub:  :wub: I love this idea.
Profile view? Ill try see if i can make one... (headed off to google to find some profiles) B)
QuoteProfile view? Ill try see if i can make one... (headed off to google to find some profiles) B)
Oh thanks.
When I try this I did not decide shape and position of engine coolers and compressors. IMHO this is a difficult point.
Now I am waiting for your rendition :cheers:  :cheers:  :cheers:
A veiw from the side
Dark marks the P-38 parts. Light grey marks the mosquito parts. Top of mosquito fuselage has been cut down to fit onto the P-38. If you use the mosquito engines, or perhaps even spitfire or mustang engines (the front end), you wont need to add the radiators.
Edit: The underside of the P-38, at the aft wheel bay, it has been deepened out to make a clean fit.
The Airfix Mosquito and P-38 are quite cheap, and so is the academy P-38. You can use the sprues to fill in the gaps.
Thaks a lot  :)  :)
But I would prefer the original engines: they are so cool  B) Perhaps prolonging bnacelles aft wing trailing edges. :cheers:  :cheers:
