avatar_NARSES2
The Flying Machines of Unconventional Means GB - Discussion
Started by NARSES2, February 24, 2019, 06:15:39 AM
This is the place for your general chat
I've always wanted to build a tilt-winged C-130 and now is my chance to do it  :banghead:
tigercat
Would CAM tech work for a WW2 ZELL .
I suspect  it might be too bulky ?
OK, what's 'CAM Tech' then?
strobez
OOoh... this looks like it might be the perfect spot to try the Fanjet from the Macross anime that I've been thinking about for a couple of years....  Is that unconventional enough?
Thanks!
You're all thinking too small and too conventional.
Either the Revell Hannebau or the larger Squadron one.  Or there's the Pegasus)?) TR-3B
"Visit Scarfolk today!"
strobez
Wait... I changed my mind.  Do we have to know HOW it flies? Or can we just say it does and leave it at that?  If so I'm going to build the Dr. Lao's flying jar machine thingy from the ancient anime TV show Future Boy Conan.  It's been on my list of Miyazaki/Studio Ghibli related builds for a while, and since I started moving forward on my Ohm build, I uncovered some of the supplies I had amassed in anticipation of the build.  Seems like a good place to try it out.
Thanks!
Kinda related question: does it have to fly by credible aeronautical principles, or can it be completely fantastical?
The reason I aks is that the term 'flying machine' makes me think of things like this:
(those arn't hot air ballons BTW - they're copper spheres with a vacuum inside them...)
Wearing my Moderator's Hat, and before consultation with my esteemed colleague Mr. NARSES2, I'd say ALL of those idea are admissible.
So go for it, you lot!
Quote from: PR19_Kit on February 24, 2019, 11:41:16 AM
Collapsed Anti Matter.  A material commonly used as a Spacecraft weapon in Iain M Banks' Culture universe.   :mellow:
For this GB my main build will be a Fairey Rotodyne 2.0.  As side builds I may dabble with one or all of the following; an autogiro, an ornithopter (with working "flap" - that will take a bit of thought), a racing ekranoplan, a flying car and something silly involving bits and pieces from the parts boxes.
Quote from: Weaver on February 24, 2019, 09:49:07 PM
(those aren't hot air balloons BTW - they're copper spheres with a vacuum inside them...)
Vacuum dirigibles are another Sci Fi staple.  In one concept lift is generated by vacuum "filled" buckyball spheres.
This may be one GB where Eric has as many entries as Dizz...
loupgarou
Beg your pardon, but the rules gave me some doubt.
At the beginning, the basic idea was "vertical take off", but now I see: "unusual or unconventional at the time it was conceived. ..., Helicopters and other rotary types"
But TODAY helicopters are NOT unconventional. So a modern day what-if helicopter is allowed or not? Or only pioneer helicopters (let say till late forties)?
Quote from: loupgarou on February 25, 2019, 12:32:22 AM
I'm NOT a moderator, but I think this clause may clarify things:
QuoteIf you have an idea for something that gets off the ground (or tries to) by methods other than the vehicles forward motion causing air to travel over an aerofoil surface then it's probably included.
So anything that isn't a fixed wing being pushed forward through the air is probably okay.
