1:72 Boeing V-44 Quad Tilt Rotor
Started by jalles, March 10, 2019, 08:01:48 AM
Quote from: rickshaw on May 08, 2019, 05:36:39 PM
but the spinning motion can consist of some string around the mould, held in your hand and spun over your head.
The mind truly BOGGLES!  :o
What could possibly go wrong, eh?
Quote from: PR19_Kit on May 09, 2019, 01:01:50 AM
A great deal depends on the quality of string used and the availability of a large clear area in which to spin.
Quote from: Rheged on May 09, 2019, 02:18:14 AM
Suitibility of the available area can be assessed if one has a cat...
;D
I wonder what my neighbours would think if they saw me doing that in my back yard. They're already convinced I'm off a different planet anyway!  :o
Quote from: PR19_Kit on May 09, 2019, 03:40:51 AM
Now why would they think that, Kit?   :banghead:
The problem Jason has is time. He's using the same stuff I do I think, aluminite.  You have 30 secs to get the stuff into the mould, and that includes stirring time for the two part resin components  ---  :-X
jalles
Quote from: kitnut617 on May 09, 2019, 07:04:27 AM
I'm actually using EasyFlo 60 Casting Resin. And while it does set up quick, it seems to be a little more forgiving than aluminite. I mix for 20 seconds and then probably get a 45 seconds of low viscosity and it's pretty much unpourable after two or three minutes.  I should time it next time.
D'oh! got you mixed up with sandiego ----
Just tell them it's a bird scarer and you are protecting your seedlings  ;)
jalles
A little more progress, I'm going to use the landing gear from a KC-135 but the axles are too far apart. I cut off the old axles and have drilled holes for the new ones with the correct spacing.
quad-tilt-rotor-09 by Jason Alles, on Flickr
I decided I didn't like my prop hubs so designed some new ones with bigger fairings for each blade. The new one is one the left.
quad-tilt-rotor-14 by Jason Alles, on Flickr
I've painted the pilots and the cockpit interior is finished. This is a big step as I can finally attach the clear section and finish PSR.
quad-tilt-rotor-10 by Jason Alles, on Flickr
quad-tilt-rotor-11 by Jason Alles, on Flickr
quad-tilt-rotor-12 by Jason Alles, on Flickr
quad-tilt-rotor-13 by Jason Alles, on Flickr
It's not super detailed by any means, but enough to look busy.
loupgarou
Could be much worse, Kit.  ;D
In the good old days, the "spinning" system for castings was also used for METAL castings. Imagine spinning around your head a mould filled with molten metal!  :banghead:
Model railway "cottage industries" used this system, and a friend of mine had to use it for dental castings.
Quote from: loupgarou on May 24, 2019, 12:31:06 AM
If you are the one doing the spinning then you would be relatively safe as in the event of a failure the molten metal/resin would go outwards.
On the other hand, if you were the one walking unannounced into the garage with a cuppa and a bikkie...
Lots of room in that cockpit.  Given the shape of the nose I almost expected the crew (PJ Productions?) to be wearing International Rescue uniforms...
To avoid that we built a small centrifugal casting machine in metalwork at school  ;D We used to melt milk bottle tops for our Al. Loads of fun with Mr Troupe who was only a couple of years older then us  ;D
Quote from: jalles on May 23, 2019, 07:36:56 PM
Some super work there Jason, but ---- (always a but, right! :laugh: )
I was told by someone who worked on the V-22 in the design office, that all the present kits of the V-22 except the new Hasegawa kit, are all modelled on the first 6 prototypes, the nacelles were redesigned for production V-22's and look quite a bit different now. Like the spinners, they don't have the fairings at all -- this photo I took at the Yuma Airshow a few years ago.
