avatar_Tophe
Boulton-Paul P.97c (finished page 3)
Started by Tophe, May 30, 2019, 08:52:16 AM
Ahem, this is a short-run kit, and it seems impossible to build it completely without sandpaper...
Probably I will follow your advice and buy disposable masks to sand (a little).
Quote from: Tophe on June 08, 2019, 10:35:03 AM
Thanks (to have the same taste as me, not only the same first name, Chris...)
Yes but Christophe is just so much nicer sounding then Christopher I think. And it's just one letter  :banghead:
Thanks.
Quote from: Tophe on June 06, 2019, 06:19:23 PM
The main problem for me (bad modeller, sorry) is that, this time, I will have to use the thermoformed canopy. With white glue?
Maybe I will do differently with the canopy, as I will have a P-51 kit that I know including 2 (injected) canopies, see
https://www.whatifmodellers.com/index.php?topic=46599.0
One of those canopies may be used on the P.97c (sigh of relief)...
I have shortened the pod, then started to add putty to make it one piece again:
b29r
Wishing you absolutely the best result for your surgery  :thumbsup:  And you should for sure listen to your wife.  I do love your project, and these wonderful kits and ideas that somehow escape me.  Good luck with yours.
Best regards,
Kem
Thanks for both health and model ;)
For the P.97c, the current step is not the most pleasant: adding putty on the second side, then some more on the first side after filling the main holes... :-\
ericr
another courageaous adventure !  keep on !  :thumbsup:
Thanks a lot! ;)
Your support helps me going on and finishing...
(I admire the ones like you Ericr or Dizzyfugu presenting only finished models as this was easy...) :thumbsup:
The pod is sanded.
Then the P-51D Heller extra canopy (injected plastic) is glued on.
Then putty addition again, to include properly this canopy (and fill the holes):
Here is the new project of model:
Then gluing booms & foreplane:
The P.97c is taking shape, with a layout like zero aircraft in the Real World...  ;D
Painting the underside (into a single colour: light blue):
