avatar_Scotaidh
Lightnings ... um ... edited
Started by Scotaidh, June 10, 2019, 09:16:27 AM
Scotaidh
I've always liked the EE (later BAC) Lightning, ever since I found that the Mk1 (model) could balance on it's stabilizers and fin ... so I've decided to edit the basic shape a bit.
Two bits, actually - first by chopping
and then by stretching:
Kindly disregard the missiles' mis-positioning on the stretch image - they'll be in their proper place on the model.
Congratulations! :thumbsup:
EDIT: you made me dream of similar Mirages (https://www.whatifmodellers.com/index.php?topic=10054.135 ), thanks!
As the original Fright'ning was not exactly renowned for its long legs, I'd hate to think what the range is on the chopped version! :o
Mind you, it looks cool, & that's what counts! :thumbsup:
Not sure how I feel about the stretched version but at least it'd have a better range. ;)
Quote from: Old Wombat on June 11, 2019, 04:24:27 AM
It'd be a 'point defence fighter' I reckon.....
A very SMALL point!  :o
Quote from: PR19_Kit on June 11, 2019, 04:53:36 AM
Rutland Territorial Defence Force ?  :mellow:
Quote from: NARSES2 on June 11, 2019, 06:32:49 AM
Might be too big an area................  ;)
Quote from: PR19_Kit on June 11, 2019, 06:53:30 AM
Will it have enough fuel to get to the end or the runway?
Quote from: Gondor on June 11, 2019, 10:09:35 AM
It's a tail sitting VTO fighter, the 'runway' is 0 ft long.  ;D ;)
Quote from: PR19_Kit on June 11, 2019, 10:43:13 AM
Ah but for landing, succesfully, the runway will have to be VERY long!
Scotaidh
Well ... much as Kit believes all aircraft need would look better with longer wings, I feel that most military aircraft are disproportionately short and would be improved, both aesthetically and in handling characteristics, by being stretched a bit.
My justification is the long-tail P-40.  I'd never really thought about improving it - it just was, if you follow me.  Then I saw the two version side by each, as they say here, and it was one of those epiphany moments.
So, some factors for the ideal aircraft:
1: A British test pilot (BTP) saying that the only aircraft he'd ever flown that had "enough wing" was the Vulcan;
2: Another BTP saying that the only aircraft he'd ever flown that was properly powered was the Lightning;
3: Me saying that most aircraft are not long enough to be pleasing to the eye;
and we get a stretched thin (Vulcan-profile) winged Javelin powered by a pair of Pegasus 107s.  :)
Personally, I'd give the second - lengthened - Lightning a delta wing, because it would look cooler.  I'd also raise the nose, giving it a bigger radar and a chin intake.  I've been wanting to do that to a Lightning for some time.
Quote from: Scotaidh on June 12, 2019, 01:42:37 AM
One above the other?  ;D ;D
Scotaidh
Right.  Since I'm doing both models more or less at the same time, I've combined the build files.  Latest Progress:
The wings are on the Chopped Lightning, and now I'm doing the RWR. This is an upgrade, obviously, to the basic airframe. :)
I'm also upgrading the missiles. I'm not sure if I should go for Sidewinders (or the Matra equivalent) or something a bit longer ranged, like AIM-120 AMRAAMs. Maybe figure out how to have both types of missile capability?
Someone mentioned range - I think that will be unchanged, as there's a lot more wing space. ;)
Finally done with the Stretched Lightning fuselage PSR. Sheet plastic stiffeners under a layer of Aves under alternating layers of Squadron Green and White. New wing locations established. I left the mounting stubs on the wings, and cut holes for them so they're positively located. I'm sure the Jokster Modeling god, Locus, will mock my attempts at port/starboard equal locations, but I did measure - twice. :) The wings are, right now, just on with Testor's Liquid Model Cement which usually gives me good results in spite of the fact that the model is _not_ a liquid ... Once that dries, the joints will be reinforced with super glue.
The short Lightning ("Shortening"?) reminds me of the Boulton-Paul P.111 and P.120...
