avatar_NARSES2
The Engines - More or Less GB :The Rules
Started by NARSES2, June 18, 2019, 06:58:02 AM
Quote from: PR19_Kit on June 23, 2019, 07:31:44 AM
Ugliness, or otherwise, is not a factor that's important in the Whiffness of any entrant.  ;D ;)
Not in the whiffness, no.  But it is an important factor nevertheless.
63cpe
Still some questions to understand the rules:
1) Is it allowed by the jury, board and committee to use an old build model which will be taken apart and reassembled totally different then before to meet the GB requirements?
2) Is it allowed to build an aircraft which is entirely new from parts of existing models? I mean; rules of the GB could be understood that only a conversion of an existing model is eligible.
An new and entirely different aircraft (kitbash whif build from parts of two or three different models) was just not known before and could have had any engine arrangement as it was not existing. Therefor it might get unclear what the engine arrangement was and how it got whiffed by re arranging the engines, Risk is to get disqualified for the GB.
David aka 63cpe
Hm, could you make that MORE complicated please, it won't be much of a mental trial for us as it is..............  ;D ;)
The mods will mod and get back to you in that...............eventually.  :o
63cpe
Sorry for causing headaches. I guess i'll proceed with it anyway. And see if it eligeable or not.
Thanks,
David Ajax 63cpe
We've done our moderating thing and decided you're OK to go with this so long as :-
a) You don't start re-assembling the bits until July 1st and
b) No one kit can constitute more than 25% of the resulting build.
63cpe
 :thumbsup: okidoki!
Thanks you for doing you moderator thing! ;D
David als 63cpe
Supertom
I can't remember if this was discussed, but on the topic of re-engining, would converting something from Alison T56 engines to RR AE2100 (that's not a C-130) apply? It's a whatif, I promise.
Converting is fine, you just have to change the overall number of engines. If the original aircraft has four engines, in order to qualify for the GB, it will now need to have 3 or 5 (or 1, 2, 7, 54, etc, just not 4 like the original.)  :thumbsup:
It's not the type of engines, it's the number that counts.  ;D   (pun intended)
Quote from: TheChronicOne on July 03, 2019, 10:21:37 AM
Well at least SOMEone has figured out what it's all about!  :thumbsup:
And even zero engines would be fine, so long as the original design had one or more.
A most succinct and appropriate definition!!  I'm rather hoping that someone will take up your suggestion of 54 engines, I'm assuming VTOL with lots of lift cells.................... but it might be something else entirely.
The minds boggles at either......... 54... or ZERO.  I find that fascinating; I'd like to see someone totally remove the engines from something....
Dornier Do X with 54 Genet Major 1A (Civet I) @ 145hp each. ;D
Or perhaps 66 Pobjoy Niagara.  :wacko:
The grilled version of course.
Quote from: TheChronicOne on July 03, 2019, 03:28:21 PM
You mean like the XCG-17?   ;D
Quote from: joncarrfarrelly on July 03, 2019, 04:44:02 PM
And Aircraft in Miniature does a 1/72 scale conversion for that ---
https://www.hannants.co.uk/product/TWC72016
 :o :wub: :wub: :wub:
Now that is cool!
It would be pretty neat to model.  :mellow:
Ground crews probably drew nipples and stuff on that one....   ;D
