avatar_Weaver
Britten Norman Islander/Trislander
Started by Weaver, July 17, 2019, 01:47:45 AM
Slightly surprised to see that there was no topic for this. If there is and I've missed it then by all means merge them, please mods.
So... this is what I was thinking about at work yesterday. Whether this reveals more about me than about my work or vice-versa is something I'll leave others to speculate upon...
If you add an engine to an Islander, you get a Trislander. Let's extend this naming principle for inspirational purposes:
1. Add a pressure cabin for the crew plus an operator. Add vertical cameras in the centre and rear fuselages, or radar in the nose, or electronic sensors, or air-sampling systems. Replace the engines with turboprops or turbo-supercharged diesels (use Do 28 engine pods). Replace the outer wings with much longer span ones.
What have you got? A Highlander.
2. Add a pressure cabin. Replace the engines with vertically firing rocket motors. Replace the wheels with landing pads. Replace the outer wings with large fuel tanks. Replace the tail surfaces with a large communications dish.
What have you got? A Moonlander.
3. Replace the engines with turbo-generators. Add four electric-motor-driven props to the wings. Add solar panels to all the upper surfaces.
What have you got? A Greenlander.
4. Add skis, cold-weather detail mods and sensors for arctic/antarctic research.
What have you got? An Icelander.
5. Add a deep flying-boat hull.
What have you got? A Sunderlander.
6. Have the aircraft built under licence by PZL.
What have you got? A Polander.
7. Fit the aircraft with terrain-following radar and an automatic flight control system.
What have you got? A Lowlander.
8. Convert the aircraft for use by US Navy special forces.
What have you got? A SEALander.
9. Use a Highlander (qv) for covert surveillance OR use a Lowlander (qv) fitted with FLIR/PNVS and silenced engines (ducted fans as tested on a real Islander?) for covert insertion/extraction of special forces/intelligence agents.
What have you got? A Spylander.
10. Make a fully-lightened Islander with a skeletal rear fuselage with lots of circular holes in it to take part in a STOL competition.
What have you got? A Collander.
11. Paint an aircraft in a promotional scheme for a recent Hollywood musical movie.
What have you got? A LaLaLander.
12. Paint an Islander as Ben Stiller's personal aircraft.
What have you got? A Zoolander.
Hehehehehe.  ;D :thumbsup:
If only the kit was more available it'd be a good basis for GB.  ;)
And in the worst case, where you model one bashed into the ground..........
What have you got? A Crashlander!
Quote from: PR19_Kit on July 17, 2019, 02:30:33 AM
LOL - there were a bunch of other names that I thought of, but I couldn't think of a design change that would justify them, so I'll leave them for others to find.  ;)
Eng-er-lander - Specially modified example for ferrying supporters of the national soccer team to away matches.
Quote from: zenrat on July 17, 2019, 03:37:27 AM
With New Order's 'World in Motion' being the only musak played on board no doubt?  ;D ;)
Martin H
Then theres the Mainlander.
A C-160 sized trash hauler with the same engine layout as the trilander......... ..
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
Quote from: Martin H on July 17, 2019, 07:18:19 AM
I like the sound of that.  :thumbsup:
And while we're on such a theme, a Herk with a similar engine setup would be a shoe-in for the current GB.  ;)
I've always liked the "Tuppeny Trident" since I flew in one years ago. I agree that, given a suitable kit, this would be a remarkably interesting group build.
TsrJoe
bit of a long shot, does anyone have a copy of the BN. Trislander conversion article published in Almark Modelworld magazine back in October 1972 ?
cheers, Joe
An alternative "Sealander": G-AVUB being tested on HMS Hermes in 1968. Apparently it landed on and took off without any problem, and didn't use arrestor gear or the catapult either:
Apologies for the low resolution of the pics: these are the best I could find online. The June issue of Aviation News has an article about the Islander which includes a high-res version of the push-back picture, although it doesn't have any more information about the trial than I've put here.
Now I'm imagining a fully-navalized version for use from the Harrier-carriers, with AEW nose (which I've got Spot-On's conversion set for), folding wings, Skyvan engines and a booster jet engine mounted DC-10-style at the base of the fin (use a tiny-scale DC-10 kit for the conversion).
IIRC the OV-10 and even a C-130 was tested for carrier operations! There also were serious thoughts to create a COD aircraft from the DC-9 airliner!
Quote from: Dizzyfugu on June 17, 2024, 01:57:22 AMIIRC the OV-10 and even a C-130 was tested for carrier operations! There also were serious thoughts to create a COD aircraft from the DC-9 airliner!
And from the BAe146/Avro RJ (I've seen the drawings) and the Fokker F28 (not a typo: the twin-jet airliner).
The 146 would have had an F-4K style telescoping nose leg, not for take-off attitude, but in order to get the top of the tail low enough to get into a USN carrier's hangar. :o
Somewhere there's video of the C-130 landing, sans hook too. IIRC it was aboard the USS Forrestal.
Yes, found it here, if you can live with all the adverts..............
https://www.military.com/video/military-aircraft-operations/carrier-landings/c-130-carrier-landing-without-hook/2812569251001
