avatar_Tophe
British F-20
Started by Tophe, August 25, 2019, 11:32:27 AM
It seems the designers of the English Electric Lightning have improved the F-20 Tigershark design, with double power (and no asymmetry if one jet fails):
And here is the profile:
Combine this idea with the X-29 FSW. Hmm!  :wacko:
Years ago I started a project to siamese two F-5s together belly to belly to make a four-engined version.
...or you could cut away the lateral air intakes, fair them over and add a single, large chin intake?  :o
Thanks!
Quote from: Weaver on August 26, 2019, 04:11:47 AM
And yes, a F-20 version of this (twin-nose vertical layout) occured!:
Mine would probably have looked something like this.
Basis is that the Airfix F-5 is split horizontally just above the bottom line of the fuselage, so two will siamese together.
Intakes are F-4, blended into the F-5 with lots of PSR.
I've used standard wings and tailplanes here, but an alternative would be Mirage deltas.
Twin fins is also a possibility.
double tiger by Harold Smith, on Flickr
It seems there was another English-designed F-20, a twin-boomer!:
Hmmmmm.........  Four engines, place the wings in an X position, laser cannons on the wing tips?
nighthunter
Quote from: kerick on September 02, 2019, 10:29:45 AM
:wacko: :wacko: ;D ;)
I may try to draw this F-20Ke if you explain a little more:
are the X xings external of the booms?
or are the booms at the tips of the upper wings?
or else?
:unsure: ;D
from https://www.whatifmodellers.com/index.php?topic=46894.15
Quote from: Tophe on September 23, 2019, 05:29:11 AM
Yes, the MiG-56 is born:  :unsure: ;D
No, seriously (not about Mig-28 nor F-5 but F-20): UK is the motherland of the General Aircraft Twin-Hotspur and that gave life to the British Twin-shark:
Here is the complete family in this direction:
Magnificent!! I love this pointy airplane!   :lol: :mellow:
