1/35 Diorama Base
Started by Ramba, September 03, 2019, 04:10:43 PM
Looks ok to me, and like anything else, you get better with practice.
Ramba
Quote from: Rick Lowe on September 16, 2019, 01:39:38 AM
Thanks! I have enough camo decals to hope to not have to hand paint camo. The decals are so much easier, for me.
Ramba
Been two weeks since I last touched this dio base. Today I only managed to get the ground finished. Some small touch ups here and here to be done. I also still need to paint the window frame and weather the brick wall.
Ramba
Started painting the figures for the dio base. Not done yet, still need to paint a lot more on them.
The non-military parkas really make this pop! :thumbsup:
Ramba
Ramba
Clear coat on to protect the paint. The camera flash makes the clear coat look glossier than it really is. The clear is actually semi gloss. The flash also highlights all my crappy hand painting hahahahahaha! Still need to weather the figures then flat coat them. For now, just dry fitting the weapons which as you can see still need painting and also still need to paint the window frame and weather the brick wall.
Again, I see not faults with the paint work. :thumbsup:
Ramba
Quote from: Old Wombat on September 20, 2019, 04:55:13 PM
Thanks again, greatly appreciated!
Ramba
I just realized I forgot the air filter on one side of the gas mask so just added that. I also painted the flamethrower and attached it. I also attached the conduit for the gas feed line. It is a 1mm OD conduit that is stretchy. Black Dog included a resin feed line but it came snapped in the box so I just replaced it with the conduit. It is made for Tamiya racing RC cars.
Ramba
Added a shark mouth to the flamethrower. Finally weathered the brick wall too. I just need to weather the figures and flat coat them.
