avatar_Tophe
Junkers EW.50 (finished page 2)
Started by Tophe, January 18, 2020, 08:09:50 AM
I am going to build, modified, the weird (VTOL?) Junkers EF.50 (Entwurf 50? my version will be the EW.50).
This is a Unicraft 1/72 kit:
The EF.50 at 1/72 being too big for my shelves, my project is to reduce its size into a little glider:
First drops of glue then first putty:
I had used a drawing I made more than 15 years ago (from a photograph), but now I may correct it with the 3-view drawing included in the kit:
I like that EF corrected ! Cool !
Thanks!
Sanding then putty again: :unsure: <_<
Sanding number 2 is done, to be completed, and I think I will use the huge propeller blades as a central rotor, with the top of a P-51 tank as rotor head: <_<
Putty again (last time I hope):
The 3rd sanding is acceptable (for me, not severe) and the rotor is built: <_<
The whole is taking shape now:
TomZ
Are you sure that prop is big enough?
Look a bit small to me  ;D ;D
TomZ
Yes, you are realist, while I am a dreamer... What-if...? ;D ;)
Building the model is finished, ready for paint: <_<
(the rotor is just put on top, not glued yet, to ease paining) :unsure:
Scotaidh
Thanks a lot! (even if such a huge enthusiasm is probably ironic): <_<
Now painting the underside:
