Arado Ar 540 "Kondor"
Started by col_kilgore, February 15, 2020, 02:45:25 PM
strobez
Yeah, it's telegraphing nicely.  I like WHIFs that look like they were meant to be that way.  It's like releasing its true form from the plastic that constrains it!
Thanks!
You mean taking a piece of plastic and carving away everything which isn't Whiff?
col_kilgore
A bit more work done last night , I decided to change the vacform canopy for one from an Airfix Me 262 , the vacform was just a bit too difficult to work with , although I have had to do quite a bit of chopping and shaping to get the 262 canopy to fit !
I'm going to try and scratchbuild a simple interior , nothing too detailed , just something to suggest that there is something in there .
Next job after that will be a bit of panel line scribing on the wings and fitting them properly to the fuselage.
strobez
It fits together like a glove.  That's amazing!
Thanks!
Cool. Looks a lot like a Yak-25R "Mandrake" recce aircraft?
Quote from: Dizzyfugu on March 11, 2020, 01:22:01 AM
The Mandrake, a Soviet copy of the PR19.  ;D ;D ;) ;)
col_kilgore
Just out of curiosity regarding the above , is there a reason why  Russian aircraft designers seemed to follow a set design / configuration ?
The Yak 25 seems easily confusable with the Il 28 , or early russian jets all look like like different versions of the same aircraft .
col_kilgore
Quick and simple cockpit made up , obviously not "prototypical" but just enough I think to suggest there's something there !
Quote from: col_kilgore on March 15, 2020, 12:28:44 AM
Centralised design philosophy perhaps? It'd be part of the Communist doctrine that all designers should follow the approved procedures.
See the Wiki entry for 'Tsagi', which was exactly that, a centralised design institute.
https://en.wikipedia.org/wiki/Central_Aerohydrodynamic_Institute
