avatar_kerick
A-10 seaplane fighter
Started by kerick, February 29, 2020, 10:15:30 AM
Here's the pics I promised.
Blue is the clipped Skyhawk upper wing. Much chopping was required between removing from the half finished model and what you see.
The underside. I boxed in some future wheel wells and then covered the hole thing with really thin polystyrene from a food package box.
I wrapped sandpaper around a piece of 1/2 inch copper pipe to sand a trough where the A-10 fuselage will fit. The Skyhawk parts got really thin and had to be glued back together. it will be much stronger when mounted on the A-10.
I added thick pieces of plastic to the outside edges so that I can round them off later.
Quote from: PR19_Kit on July 10, 2020, 05:10:22 AM
WHAAAAAAATTTTTTTT!!!!  :o
I would like to second the honourable Gentleman's reaction WHAAAAAAATTTTTTTT!!!!  :o
:bow:
Damn, ok! We're going for the gusto here!  :mellow: :mellow: :mellow:
Now that's scratchbuilding.
Thank you gentlemen!
Sanded down the saddle with 400 grit. Some fine tuning of the front mating surfaces produced a better contact with the fuselage. Going to have to work out the main gear. It will be having some very long struts. The A-10 main gear plus the Skyhawk main gear might work.
Any suggestions on a color scheme?
Can't believe its been July 10th since the last post on this project! Lots of things been going on here so maybe it will calm down and I can get something in now and then. Anyway, I cut some wheel wells in the middle bay and am gluing up some gear legs from the A-10 kit main gear and the leftover main legs from the afore mentioned Skyhawk. Still not long enough so adding some blocks inside the wheel bay. Raising the wing and adding a float makes for a tall fuselage. I'll post pics when there is more to see. I hope that is soon.
It's good news that this nice (nicely crazy) project is not cancelled ;)
Not canceled at all, just delayed. Going through a period of total lack of interest in nearly everything. I think some of it is from the meds I'm taking but other factors are involved. Hoping some other things will calm down and allow some progress.
I wish you to feel better (and I say that not egoistically to enjoy the final model, I sincerely hope you will feel good). :-\ :unsure:
Scotaidh
Quote from: Tophe on August 28, 2020, 09:03:57 AM
What Tophe said.  :)
So now we have some legs!
A combination of A-10 legs, Skyhawk legs and some sprue.
Now I have to cut a hole for nose gear.
The whole saddle device worked very well. Attaching the wings should go well. More PSR around the saddle and a few touch ups.
An amphibious A-10 is even more complicated to build then a genuine A-10 seaplane. Congratulations for your courage and skills. :thumbsup:
Holy crap, dude.  This is so ambitious... I can't wait to see the end result.  :blink: :mellow: :mellow: :mellow:
