avatar_63cpe
Lockheed Viking AEW4
Started by 63cpe, March 05, 2020, 08:56:53 AM
63cpe
Meanwhile the build off the Lockheed Viking AEW4 also started. Here some first pictures I'd like to share.
At first all in normal. Start is, as always with the cockpit:
IMG_20200305_083945016 by Buddy Holly, on Flickr
I decided to put in a pavla cockpit in as the airfix one is really poor in detail.
IMG_20200305_084027070 by Buddy Holly, on Flickr
After closing the fuselage halves a gap of 2 mm was left of the slightly too wide pavla cockpit (and my lack of checking)
IMG_20200305_090932772 by Buddy Holly, on Flickr
But, nothing to worry about as putty will close the gaps. But, oh what's happening...that tail is totally the wrong way!
IMG_20200305_124523038 by Buddy Holly, on Flickr
Ah, that's what's happening: the radar disc is going on top off the tail. Engines are from an ancient Matchbox A-10 (the grey plastic was getting yellow!) and are supposed to go on the leading edge of the wing.
IMG_20200305_131132042 by Buddy Holly, on Flickr
Hope you like it!
David aka 63cpe
Quote from: 63cpe on March 05, 2020, 08:56:53 AM
I've had that happen with Pavla cockpits I've used too.
I think their rulers need re-calibrating.................
jalles
Fantastic start! Is this going to be like smaller Antonov AN-71 with the engines above he wing?
That's looking very good.  :thumbsup:
Quote from: PR19_Kit on March 05, 2020, 10:41:09 AM
I'd like to be associated with those comments. They look great, but do they fit ? Do they heck. I got a lot when I got back into the hobby as I though it was the thing to do. I still have most of them and I doubt if they will get used the fit of the ones I did try was that bad, non existent in fact.
Quote from: NARSES2 on March 06, 2020, 01:38:03 AM
I'm glad it's not just me.  :thumbsup:
Some of them are OK, others need vast amounts of the fuselage moulding filed or Dremeled away before they fit. Don't they ever test fit them?  :banghead:
63cpe
I Use the pavla cockpits often and most are ok-ish. They always need trimming...some more than other though...
I forgot I was too lazy to check the fit anyway. I should have known better. Anyway, it's fixed now and putty number 2 is curing. Time for an update:
After the first putty and sanding this is the result:
IMG_20200306_120635543 by Buddy Holly, on Flickr
IMG_20200306_120642228 by Buddy Holly, on Flickr
The rudder needed a wider chord, so a 747 stabilo was cut to fit.
IMG_20200306_120700396 by Buddy Holly, on Flickr
The MAD boom is still operable:
IMG_20200306_120706025 by Buddy Holly, on Flickr
IMG_20200306_120714192 by Buddy Holly, on Flickr
IMG_20200306_120734078 by Buddy Holly, on Flickr
Had to put the canopy on and puttied the seams again:
IMG_20200306_120801221 by Buddy Holly, on Flickr
IMG_20200306_120812089 by Buddy Holly, on Flickr
It definetly looks like a mini Madcap (An-71/74):
IMG_20200306_120844529 by Buddy Holly, on Flickr
David aka 63cpe
I can see the Madcap likeness, but I can also see a Beriev influence in there.
63cpe
Thanks gentlemen!
David aka 63cpe
AndrewF
Excellent! Especially the fin support for the radome.
That is so cool ! After seeing the first pics with the engines on the table under the machine I had to do a few scroll up/ down moves lol. Love it !
63cpe
Update time!
Wings are curing an the engines ar on the wings...
IMG_20200315_102143862 by Buddy Holly, on Flickr
IMG_20200315_102035944 by Buddy Holly, on Flickr
IMG_20200315_102021173 by Buddy Holly, on Flickr
IMG_20200315_102005540 by Buddy Holly, on Flickr
IMG_20200315_101942163 by Buddy Holly, on Flickr
IMG_20200315_101927627 by Buddy Holly, on Flickr
PSR continues
David aka 63cpe
That's given me an idea of what to do with the Airfix Bristol Superfreighter  :thumbsup:
