avatar_Dizzyfugu
DONE @p.2 +++ Yokosuka J1Y3 "Akaei" light fighter of the IJN, early 1945
Started by Dizzyfugu, March 27, 2020, 12:24:40 AM
And also many thanks for a consideration of this one for the next Whiffies!!!  :lol:
Quote from: Sport21ing on March 29, 2020, 07:19:24 AM
Quote from: Dizzyfugu on March 29, 2020, 03:39:03 AM
I won't deny that. But, from my personal point of view, it's either poorly researched, or purposely edited in a fashion that's begging for skepticism, just exploiting the exotism of the designs.
Yes, true, with many butterflies prior/during the war (and alien technology), but still, with a little of imagination :D
I must partly apologize, since I found out in hindsight that the J4M actually existed as a paper project, and that some interpretations bear a strong resemblance to the depiction in the comic (including the pointed fins). It's also amazing that it looks like a twin brother of the Ki-98. However, it still was a land-based IJN fighter, so the carrier use is still fishy.  ;)
I had a feeling you would be starting with a Vampire.   ;)
I have a weakness for inverted vertical tails.   :thumbsup:  Good job.
perttime
Browsing some magazine, I recently saw photos of real world Japanese WWII aircraft. They looked a bit used. Just like this one.
Harsh conditions, or not all that good paint?
No primer underneath. I just imagined that material scarseness could result in such a look, the undersides were left unpainted, too.
Quote from: zenrat on March 30, 2020, 02:26:27 AM
Well, the rear fuselage lends itself to a pusher prop conversion - either with an implanted radial engine, as seen here, but an in-line engine with a bigger spinner is also easily possible. Just the prop diameter and the correponsing  landing gear are the tricky part - but I am positively surprised how good the stance of the model looks, thanks to the short prop blades from the Dinah.
I toyed with the idea of a piston engined Vampire but I gave up when I realised how long I would have had to make its legs.
You've done well to pull it off.
A bit late to the party and it's almost all been said, but that has come out well  :bow:
loupgarou
Beautiful idea, Dizzy. A very interesting aircraft. And your beauty shots are always masterful.
Glenn Gilbertson
Interesting story, beautiful model & great photography - another triumph! :thumbsup:
