Mirage F1P
Started by PR19_Kit, March 27, 2020, 03:21:45 PM
The Special Hobby F1 has lots of very fine engraved detail, which is a pity as any PSR work means you have to re-engrave the devil out of it to restore that detail.  :banghead:
The wing joints have notable steps in them where they meet the fuselage, and the real thing is very smooth all over, so I've done two lots of PSR there so far. Looks like a mammoth re-engraving session ahead, and I hate that almost as much as I do PSR. :(
I simply work  on the basis that from 72 foot away you can't see panel lines  ;)
The last PSR's done, the panels have been rescribed and the last coat of primer has been applied.
I think I'm ready for colour coats, if only I could think of a scheme that DOESN'T include grey!
Scotaidh
What about a South African colour scheme?  I don't think they used much grey ...
...but I assume that some rather naval livery is intended?  :o
Quote from: Dizzyfugu on April 02, 2020, 02:22:10 AM
Exactly Thomas.  :thumbsup:
So by Fred's rules it has to have some blue in there somewhere.  ;D
Not so much a rule as a guideline.
I may invent a totally new Aeronavale colour scheme, one which majors on Humbrol 14 of course.  ;D
IIRC, some Étendards deployed on carrier in the Mediterranean carried not the usual dark bluish-grey/white livery, but rather bright blue upper surfaces - a bit like PRU Blue. Not certain whether this was intentionally or just a painting accident, though.
It'll do as a starter for me. Thanks very much.  :thumbsup:
I've been working on the stores for the F1P, and while the Magic missiles are fiddly, and the ECM pods just needed tidying, the underwing tanks are ATROCIOUS!  :banghead:
Not only are the two halves of each tank different sizes, so that they need lots of filing and PSR after assembly, the rather complex fins don't fit the tanks in the slightest! In the pic you can see the massive gaps where they meet up to the tail of the tank, and they need a lot of PSR as a result. For some reason SH have added a small part to the inside of each fin which is meant to fit in a slot in the tank, but they're far too large, and I've had to cut them off. That means MORE PSR to fill in the gap!
I wish I'd decided on something other than the tanks to go in the inner pylons now. :(
Perhaps a set of tanks from a different manufacturer would be better, such as Airfix or Hasegawa?
