avatar_Austanker
Waterworld Hellfire Barge - FINISHED AT LAST !!!
Started by Austanker, April 08, 2020, 02:30:44 AM
Quote from: Austanker on July 11, 2021, 08:18:14 AM
Quote from: NARSES2 on July 11, 2021, 01:13:50 AM
Looking very busy  :thumbsup:
Do you use double sided sticky tape to hold them down ? I found some nice "padded" stuff in my local £Store here in the UK a couple of years ago and bought half of what they had on display. It's ideal for that and similar jobs :thumbsup: Whatever you are using looks quite similar.
Yes thats double sided tape I'm using to hold the bits in pace, works great
Thought it was, cheers
Austanker
#91
Progress has been a bit slow but got some more done during covid lockdown , basically we are into the final stage , everything is painted and now I'm doing the base then once the water effect is done I will attach all the components to the barge
Found a good tutorial on youtube to make water effects with bog roll and watered down PVA glue it's pretty cool, its looks good
Still following this with much interest.
The Barge looks awesome
The bog roll and PVA method is worth a try and gives good results, I have used it a couple of times. What I am seeing is good results so far
The barge is looking great & the water's pretty good, too! :thumbsup: :thumbsup:
Akiyama
Austanker
Been dreading this part but it was all over in a few minutes , hooking up the final drive belts to the paddle wheel , just waiting on a few packets of spent brass 50 cal shells glue up a few more greeblies and we will be done
Nah, no way that's a model.
It's a real one and you just Photoshopped it, didn't you?
Superb work on that rusty finish  :bow:
Love the name   ;D :thumbsup:
