avatar_zenrat
Revenue Protection Cutter
Started by zenrat, April 22, 2020, 04:05:28 AM
Thanks folks.
I evened up the sides today, cleaned up some excess glue and added an extension to the vertical bit at the front.  The bit that curves up from the keel.
I know it will have a nautical comedy name,  Most parts of boats do.  Futtock shrouds and rowlocks for example.  It's probably called something like a willy post or a fore-noggler.
Quote from: zenrat on May 03, 2020, 05:15:26 AM
I have increased the freeboard.
Increased?  :-\
More like DOUBLED!  :o
Not doubled.  That's the camera angle.  Maybe increased by 50%.
Quote from: zenrat on May 04, 2020, 05:06:41 AM
I'll ask my brother next time we talk, he was a shipwright back in the day when they still made ships on the Wear.
I'd be careful with your futtock shrouds  if I were you!!  Let them get too loose and your topmast goes all limp!!
Stem*.
You're welcome**.
*I think
**I think...
Now you have enough freeboard to wedge a Trebuchet on it.
Ok, perhaps a Scorpion
Or two pair of Lewis guns.
I started on the cabin thisarvo.
Revenue Protection Cutter WIP 09-05-2020 by Fred Maillardet, on Flickr
This is completely influenced by Strobez BTW.  His builds have inspired me to build stuff I wouldn't normally try.
Thanks Womby.  It is developing a character all of its own.   I'm not sure how much I have to do with that.
I've had to stop scratching up the cabin so I can paint the areas of the inside I won't be able to get at once the cabin sides are glued to the hull sides.
The sides of the cabin look as though they could be "swing out" sails for when a stealthy approach is needed ?  ;)
Looking good  :thumbsup:
Hmmm, I see what you mean.  They are like that because I can't glue them in place until I have painted the floor, engine and other detail bits inside that i won't be able to reach later.
Quote from: zenrat on May 11, 2020, 04:47:26 AM
At least you've thought about it  :thumbsup:  ;)
Quote from: NARSES2 on May 11, 2020, 06:38:45 AM
Yes.  Unusually for me.  I usually steam right on in gluing stuff together only to realise detail painting is going to be impossible.  I must be learning...
:unsure:
