avatar_zenrat
Revenue Protection Cutter
Started by zenrat, April 22, 2020, 04:05:28 AM
loupgarou
I suggest a very LIGHT roof, and thin plexiglass windows. You risk capsizing with such an high superstructure. Or have you already fitted a depleted uranium keel?  ;D
Did I not mention the flying bridge and large mast-top radar installation?  And the helipad?
Nah, she'll be right mate.  A simple curved roof with a stubby mast on top of it holding nothing more than a radar reflector and a radio aerial.
Ammunition and equipment stowage in the hull will add weight low down.
Today i fitted "rungs" to the mast so a crewmember can climb it should they need to.
An Academy US 2 1/2 Ton truck kit provided ammunition and other stuff stowage for the aft section of the hull and a pair of 50 cal machine guns.
this is coming along great.. Such a difference between original layout and what you have
Thanks BB.
It's nearly done.  Painting has begun.
I do still need to fit the rudder but I have solved the dilemma of how exactly the internal side of the rudder actuator gear works by hiding it under an ammo box.
She looks exceptionally cartoonish, at the moment, but I'm sure zi have something up their sleeves for her.
Cartoonish is good.  I like cartoonish.
I put some transfers on today.  Nothing much, just some numbers.
Ammo stowage is in place, gun mounts built and guns primed.
I still need to scratch build one of these.
tigercat
I half expect to see an early Mickey Mouse at the helm
Quote from: tigercat on June 02, 2020, 05:53:08 AM
Yes ! Was it Steamboat Willy where he first appeared ?
Quote from: NARSES2 on June 02, 2020, 06:18:06 AM
Yep. :thumbsup:
getting more intriguing.. weapons !!!!
Surely they could get a the job done with Harsh Language and a open infringement book.
