avatar_The Rat
What? Another Swift?!
Started by The Rat, May 14, 2020, 08:13:17 PM
Oh, I like that Swedish Swift!  :thumbsup: I have an Airfix kit in the stash w/o serious plan (yet), I might pick that idea up and create a dedicated recce version (as a supplement to the Hunters). I have a surplus recce nose from a Heller Viggen somewhere...  :rolleyes: Should look good in blue/green cammo.
Quote from: Dizzyfugu on September 21, 2020, 11:32:04 PM
Glad you like it Dizzy. That was from last years One Week GB, here is the link https://www.whatifmodellers.com/index.php?topic=46573.msg845928#msg845928
It fulfilled all my requirements for the GB, easy to make and an easy paint scheme.
Okay, set up a Flickr account. Howzis?
If you see it, that's the canopy I'll probably stick on it. If memory serves, it's from the old Frog F-4K, but backward because it seems to work better that way.
sideshowbob9
Looks great and that canopy is pointing forwards
Quote from: Gondor on September 23, 2020, 01:28:24 PM
I KNEW THAT!  :o  What I meant was that I have tried it backward, and it seems to look better. I think. But that picture was taken years ago.
Quote from: The Rat on September 23, 2020, 02:31:50 PM
Having switched it in my minds eye Ratty I think you may well be right  :thumbsup:
Okay, first pic is when i stuck the new nose on a long time ago, I think I used a drop tank. Second is the PSR stage, with the canopy backward, which does look better.
sideshowbob9
Yeah, backwards definitely matches the Swift's contours better.  :thumbsup:
Quote from: sideshowbob9 on September 27, 2020, 01:07:11 AM
Certainly does, gives her a much more modern look  :thumbsup:
The forward canopy would have to open like an F-16's that way round, as there's no windscreen as such. But it looks very good nonetheless.
Quote from: PR19_Kit on September 27, 2020, 07:25:58 AM
Hmmm... You're right. If I feel industrious I could sand off the raised canopy framing, polish the plastic, and paint some frames that would allow for a better opening method. Having the canopy this way around certainly gives that back seat chappie a better view than the previous arrangement, unless I go with a single seater and have the rear part solid, like the early Swifts. Decisions, decisions...
While I decide on the final scheme and use for this bird, I got some work done on creating a sawtooth leading edge. Some scrap plastic with enough glue to hopefully weld it to the wing and allow it to be carved/files/sanded to blend in. Underside will be filled in with putty. Hmmm, how does a raspberry ripple scheme sound? Then I would have to come up with yet another fantasy role.
<sigh> It ain't easy being a whiffer.
Just pulled out an Xtrakit Swift FR.5 and the saw...  :wacko:
