avatar_zenrat
Handley Page HP.80N Victomic - Finished Pics Page 19.
Started by zenrat, June 27, 2020, 06:29:09 AM
And so it begins.
Handley Page Victomic The Beginning 1 by Fred Maillardet, on Flickr
Handley Page Victomic The Beginning 2 by Fred Maillardet, on Flickr
Today I have glued the seats to the cockpit floor and begun painting the crew.
sideshowbob9
Don't know if that tingly feeling is excitement for this project or the radiation ionising the air...
I have a decision to make.
It would be very easy for this to end up looking superficially like a simple paint whiff.  The trick will be to modify the engine housings to give the appearance of different engines whilst maintaining a "factory*" appearance.
I have dug out some Gundam parts which I will try to integrate.  "Obviously" nuclear engines require a plethora of heat exchangers, lumps, bumps, inspection panels and external plumbing.   ;)
Thisarvo I glued together the outer wings and vertical tail halves.  It's bit crude isn't it.  Was this a serious attempt at a scale model or a toy?  I know Matchbox's usual level of detail etc and was expecting that but this strikes me as being a step down.
I should get on with designing the graphics for it's prototype scheme.  I will be modelling the aircraft as it was when Kit saw it fly past at the 1956 Farnborough Show.
Suggestions please for a good name for Rolls Royce Nuclear jet engines.  Charon?  Styx?  Ares?  Cerberus?
*but not necessarily an aircraft factory...
sideshowbob9
#33
My tuppence haypenny worth. I'd extend the jetpipes aft, the less airframe exposed to bad juju the better IMO.
On the Tu-95LAL there was a bit of a hump/dome over the reactor on top of the fuselage.
Do you need heat exchangers? I thought the engines were the heat exchangers, although I suppose you might need some for when the reactor is hot but the engines are off.
APU in the tail replacing airbrakes? To power coolant pumps in case of calamity.
Styx defo!
All FWIW.
tigercat
Thanks guys.
I don't know if heat exchangers would be needed for engineering reasons but I think they will be for aesthetic ones...
Prometheus is a good suggestion.
Also Sisyphus, Oedipus (they are real mothers to work on), Tantalus, Ixion.
Quote from: zenrat on July 04, 2020, 01:39:00 AM
Ahah, does that explain why I glow in the dark sometimes?  ;)
Quote from: zenrat on July 04, 2020, 04:02:06 AM
Indeed it is. Or for something slightly out of the ordinary ; Yama is a Hindu/Buddhist God of death, Ahriman is the Persian God of destruction.
This is for the engines Chris.  Those would be more appropriate for a really large heavy bomber or some other weapon of mass destruction.  i shall make notes for possible later use.
I currently favour Ixion.  He was strapped to a burning wheel for eternity for upsetting some god or other.  Seems appropriate but it is ringing a bell for some reason.
<pause to consult google>
Ixion was the pen name of Canon Basil H Davies who wrote under it in The Motor Cycle magazine from the turn of the 20th century until 1961.  I knew it was familiar.  I may even have a book by him.
No need not to use it however as it is after all a classical reference.
Quote from: zenrat on July 04, 2020, 06:18:36 AM
Ah right  :thumbsup:
Canon Basil wasn't a Palace supporter was he ?  ;)
Quote from: NARSES2 on July 04, 2020, 06:31:49 AM
Arsenal surely?
I'll get me coat...
TallEng
I'm with sideshowbob9 here, Rolls-Royce jet engines are traditionally named after Rivers I believe?
So Styx it should be :thumbsup:
Having just Google'd/wiki'd, I now learn there were (are) five Rivers of the underworld:
the Acheron (river of woe), the Cocytus (river of lamentation), the Phlegethon (river of fire), the Styx (river of unbreakable oath by which the gods took vows), and the Lethe (river of forgetfulness)
That's enough classical education today for me ;D
Keith
sideshowbob9
Prometheus would be just fine for a Bristol Siddeley engine though. An alternative river could be Rubicon as in once the nuclear genie is out of the bottle, you have crossed the Rubicon.
Ixion sounds cool, could be the reactor's codename?
Trouble is pretty much every suggestion sounds pretty cool.
In the period in question the complexity of the task would probably have required the cooperation of all
four of the manufacturers: R-R, Bristol, Armstrong Siddeley and de Havilland - all of which became part
of R-R over time. Rolls-Royce gas turbines were/are named for rivers, Bristol engines were named
from Greek mythology, and the names were retained when Bristol-Siddeley was absorbed by R-R.
A nuclear turbojet is not a gas-turbine, thus it wouldn't really fit with the rivers naming convention, but
Prometheus could fit because a nuclear powered turbojet would be considered as bringing a new fire.
;D
